Thread: pentair minimax 400- eo2 code-- help
    Mar 2015
    brentwood, ca
    3
    I have replaced everything on this unit!! The ignitor is working fine, replaced the flame sensor, replace the high temp sensor- the unit would fire then turn off.. then fire and turn off.. I looked into the problem further and everything pointed to the power element.. I just replaced it and I verified that is it working before I installed it and now the unit won't fire!! e02- high limit code. I have good water flow.. Help!!
    Re: pentair minimax 400- eo2 code-- help
    Welcome to TFP!
    Have you checked the high limit thermal cutout switches? I believe they are L1 and L2 in the wiring diagram.
    ps0303's Avatar
    Jul 2011
    FL
    3,704
    Not sure which model you exactly have, plus or NT, but did you check the flow valve assembly?
    Paul
    http://www.gastekservice.com A word of caution: When working with gas and electrical you might want to consider a licensed contractor. Consider the value of your life and others around you. If you would like to provide a review of the help I provided, please use the following link to leave a review. gastek - Google Search,
    Mar 2015
    brentwood, ca
    3
    Quote Originally Posted by autohousemike View Post
    I have checked the flow value assembly- working fine
    I tapped on the high limit switches- after hitting the 150 limit switch, the unit fired... then turned off after a couple min.. then fired and e02 code again. probably have a faulty 150 degree switch??
    Most likely. You can jumper across the switch to make sure. If it works with the switch shorted out, that is certainly the problem.
    Mar 2015
    brentwood, ca
    3
    thanks for the assistance- I just ordered one- figured for the $35- I've replaced everything else it is 9 years old after all and for a nt400 minimax- I guess I've done pretty well up to this point!!
