Thread: Pool Renovation & Pad Plumbing
    Jun 2014
    Markham/Ontario
    52
    We are in the middle of renovating our pool and will be redoing all of the plumbing at the pool pad.
    The plumbing setup was previously as follows:
    As part of the pool renovation, we filled in the main drain, added a waterfall and redid all of the plumbing to the pad. We will be doing all of the pad plumbing when the weather warms up.
    I am eventually going to get an automation system, but for now every thing will stay manual. I am currently thinking of getting the following setup:
    The actuators, flow meters and thermometer will be added later.
    The question that I keep on asking myself is wheter I should also put in a bypass for the heater and a second bypass for the SWCG.
    What do you folks think? Any suggestions?
    Thanks.
    N.B. The attached drawing was what I was originally planning before we had added the waterfall and filled in the main drain
    15K Gallons, IG, Vinyl, 1HP Single Speed Pump, Sand, SWG, NG Heater + Solar Panels
    Re: Pool Renovation & Pad Plumbing
    I strongly recommend using a three way valve to pick between the waterfall and the pool returns, and then having manual valves on the two separate pool return lines.
    There is no real point in making a SWG bypass. Just make up a short section of pipe with the correct unions that can go in place of cell.
    A heater bypass can be useful, but also adds complexity. If the complexity doesn't bother you then go for it.
    Jun 2014
    Markham/Ontario
    52
    Quote Originally Posted by JasonLion View Post
    Jason
    What's the reason behind the three way valve followed by the individual valves on the two returns? Turbulence? Back flow?
    I can isolate flow to either return or waterfall in either setup.
    Thank you for the clarification.
    Marek
    You want each "function" accomplished by a single valve. In this case you want to be able to turn on the waterfall with a single actuator. Most automation systems can't turn three different valves in response to a single button press. The higher end automation systems can move several values, but even there it makes for much more complex programming.
