Thread: Prospective new pool owner from tampa
    Mar 2015
    Tampa FL
    1
    Cool Prospective new pool owner from tampa
    Hi: We are planning to build a pool and this site appears to have loads of information. Any advise is appreciated. Thank you.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Prospective new pool owner from tampa
    Welcome to TFP Cartman!
    Well, tell us more about what kind of pool you have in mind.
    Essential Links:
    Jun 2013
    SpringHill FL
    415
    You found the right place.
    Nathan
    15x30 gunite 18k gallons Hayward star clear plus 120sqft cart
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,009
    Hi Cartman!
    Welcome to TFP!
    The best advice I can give you is to have patience, research before you sign a contract and make your choices and decisions wisely. You will have to live with them for as long as you live in the house.
    Divin Dave,
    Mod Squad pooldv's Avatar
    DFW, TX
    24,506
    Hi, is this the real cartman???
