Results 1 to 13 of 13
Thread: make a pool shallower
    Mar 2015
    Plano TX
    8
    Any recommendations on contractors in North Dallas area making a pool shallower ? Our pool is 8feet deep on the deeper side so I want to make it 4feet high. Has anyone done this ? What a're your experiences ? What should I be looking at cost, just a ballpark ?
    Thanks.
    Jan 2012
    'burbs of Augusta, Georgia
    7,367
    Re: make a pool shallower
    I can't help you, I'm sorry. But I am curious as to why you want to do this?
    This can be done to plaster and vinyl lined pools, though it is a fair amount of work. Changing the depth of a fiberglass pool is more or less the same as building a new pool from scratch. Actual costs will vary dramatically depending on pool size etc, but very rough ballpark numbers are $6K for vinyl, and $20K for plaster. We have seen a couple of forum members who have done this, though it isn't exactly common.
    Mar 2015
    Plano TX
    8
    Thank you. Mine is plaster.
    Mar 2015
    Plano TX
    8
    We rarely use the deep side. 4' or 5' would be ideal to use the entire pool. Pool is not for swimming laps but just to chill out and play in the water. Can't do that in 8' of water.
    Kpag's Avatar
    Feb 2015
    Dallas TX
    159
    How old are your kids, if any? We have a friend who made a "scuba diving depth" pool shallower.
    IG ~12000 gallon 1988 freeform pool with IG spa, Hayward equip, Ecostar pump. Remodel done: NPT Arctic 1x2 tile in Lagoon w/ gray thinset & Light Pewter grout, French Gray PebbleSheen w/ grey fittings, Leuders buff eased edge limestone coping w/ Light Buff mortar, buff mastic
    Casey's Avatar
    SW PA
    10,457
    I would go with a minimum of 5 ft. You really don't want to go any shallower than that.
    Jan 2012
    7,367
    Quote Originally Posted by srmagavi View Post
    Sure you can on floats or in the big round tube... I love a deep end
    Quote Originally Posted by YippeeSkippy View Post
    Or drain 4' of water out! 😜
    18' x 36' saltwater inground vinyl pool
    Texasrebel's Avatar
    Mar 2015
    Conroe/houston
    28
    This is why I'm building one only four feet from the start. I must have talked to a hundred pool owners and most thought their deep end a waste. Seems you could just fill it up with concrete and replaster.
    Mar 2015
    Plano, TX
    18
    I'm guessing your pool is gunite/concrete, since most in this area seem to be. The process roughly would be to fill the deep end with concrete, but that's easier said than done. You would need to jack hammer into the existing pool shell to get down to the rebar, and tie in new rebar for the new concrete. Simply adding concrete inside the existing pool shell would certainly crack eventually, the whole shell needs to be one solid reinforced structure. You would also have to jack hammer out the current drain, and plumb in a new drain at the top of the new floor. It would probably require two drains in the new floor, in order to meet updated building codes, but that could simply be a tee fitting off the existing drain line. You would then need to replaster the entire pool for a seamless finish. Cost-wise I'm not sure how much, but you would be looking at many thousands of dollars, maybe even $10k or more.
    1982 built 15K? gallon IG gunite/plaster, DE filter, Pentair Challenger 1.5HP pump, Polaris 280, Pentair LA01N booster pump, 3-8' with diving board, K-2006 test kit
    Jun 2017
    North Fort Worth
    16
    Thanks.
    I'm here in Fort Worth and thinking the same thing. Curious if you explored this any more? Thx.
    25k In Ground Plaster? // Pentair 2 HP Pump // Pentair Centurion 3/4 HP Booster Pump // Pentair CCPlus 420 Cartridge Filter // Old Pentair Kreepy Krauly LL505G // 5 year old pool. // K-2006 Test Kit
    Sfpat's Avatar
    Jul 2016
    tulsa
    105
    That's what noodles are for. The deep end is used the most in my pool, by myself, kids, grandkids (who like to show off their swimming skills)
    40 year old pool, 35k gal w/spa, gunite replastered July 2016, Hayward Sand filter, Hayward 1.5 hp single speed pump, TF-100, Kreepy Krauly suction side cleaner
