Results 1 to 10 of 10
Thread: Another opening, another 0 CYA
    Apr 2013
    Sanford, Florida
    32
    Over the winter each year my CYA level drops from normal levels to zero. Is there anything I can do to prevent this? It's not a huge deal to re-CYA once a year, but I dumped almost 20 gallons of 10.5% in the past 2 weeks before I remembered the winter CYA disappearance issue.
    23,000 gallons, in-ground, gunite
    Hayward C1200 cartridge filter system
    Pentair 1HP pump
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Another opening, another 0 CYA
    It's very common in pools that go green over winter. Did yours?
    Essential Links:
    Apr 2013
    Sanford, Florida
    32
    Not too bad this year, but it did cloud up a bit and had some green, but not swamp territory. I generally quit running weekly tests when the daily highs drop out of the 80's. I maybe burn through a quarter or less of the chlorine I use the rest of the year. Does letting the FC get super low contribute to CYA loss?
    Pentair 1HP pump
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Yes, and the most commonly accepted theory and explanation is that it is consumed my biologial activity. (Bacteria)
    Whatever the case, you need to complete a SLAM procedure on your pool. Don't raise the Cya over 30 before you get that done.
    Can you go ahead and post a full set of results before you procede?
    Essential Links:
    Apr 2013
    Sanford, Florida
    32
    Right now I am looking like:
    FC 4
    PH 7.5
    TA 90
    CH 250
    CYA 0
    Borate 40
    Water is right at 78 degrees F. My FC is pretty stable overnight but I lose almost everything during the day, unsurprisingly.
    Pentair 1HP pump
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Ok, Not bad.
    I would increase the Cya to 30 and SLAM it. If you are comfortable with it, lower your pH to 7.3 as a target as well.
    Not critical, but you won't have to worry what it is during SLAM.
    SLAM SLAM SLAM till you're done.
    Essential Links:
    Apr 2013
    Sanford, Florida
    32
    I have a tough time seeing the difference between 7.2 and 7.6 on the pH scale. I wish there were a more accurate test. Same thing with borates.
    Pentair 1HP pump
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Which pH test are you using? For those two ranges it should pretty easy with a phenol red pH test.
    Essential Links:
    Smykowski's Avatar
    Sep 2011
    3,065
    Quote Originally Posted by aseigler View Post
    Our best guess for avoidance is to close the pool late in the summer when the water is cold, it must be clean and clear when you close, and your FC has to be at SLAM level. Cold clean water will slow down the rate of FC use, so that you will have FC upon opening, thus preventing anything from living in the water which will break down the CYA.
    Mod Squad zea3's Avatar
    Jul 2009
    Houston, Texas
    9,380
    You may want to test for ammonia before adding the CYA. Ammonia is a by product of CYA degradation due to bacteria. You can get an ammonia test anywhere that sells aquarium supplies. If it shows you have ammonia, it is best to clear it before adding the CYA. Otherwise it may continue to break down the CYA you just added. You slam with bleach to get rid of the ammonia.
    Love TFP? Become a
    TFP Supporter!
