Results 1 to 10 of 10
Thread: Automation......Thought I Was Confused Before It Arrived
    sag365's Avatar
    Jan 2015
    Ft. Myers, FL
    42
    Even before my Zodiac Z4-PSi arrived, I was looking at the installation manual and scratching my head. Now I am flat out confused!
    What I have in boxes in my garage are a Pentair Intelliflo VSP, Zodiac Z4-PSi, and an Aquatherm heater (Aquacal). My first question is, according to the instructions, to wire the pump to the relay on the Z4 controller. Does this mean there is no power to the pump until the relay kicks on? Therefore the pump control panel itself is off? If that is the case, how does the pump know what speed to run at when it kicks on? How does it get its instruction from the controller?
    My second question is, unlike the pump, the wiring diagram does not show a heater relay, only Aux 1 (which is shown connected to a blower), Aux 2, and Aux 3. Do I connect the heater to an Aux position on the Z4 controller, or wire the heater directly to the breaker and just use the 'Heater' position shown on the 'Green Terminal Bar' (top center of diagram) and connect it to the Y and Z positions on my heater's control board (Jandy control)?
    Thanks for any insight.
    16k gal, IG pool and spa, pool 29x14, pebble, 1983, 1.5" plumbing, Pentair Intelliflo VSP, Pentair Quad DE, Zodiac Aqualink Z4-PSi, AquaRite T15 SWG, Aquatherm AT115
    Mod Squad pooldv's Avatar
    DFW, TX
    24,502
    Re: Automation......Thought I Was Confused Before It Arrived
    Not for sure with the zodiac, but for my Pentair Solartouch the Pentair VSpump is wired for power direct to the breaker and the the contol low voltage cable is wired to the Solartouch. Should be the same for your pump and heater, power wired directly to the circuit breaker and low voltage control wires wired to the contoller.
    The pump relay is only used to turn the pump on or off if it is not a VS pump.
    DFW, TX
    24,502
    I scanned through the Zodiac manual quickly and it does have the ability to send pump speed to a VS pump. Also, the manuals for your pump and heater will have instructions for wiring to automation that will help. Between the three manuals it should help clear it up.
    sag365's Avatar
    Jan 2015
    Ft. Myers, FL
    42
    @pooldv
    Thanks for the input. How does it supply info to the pump? Cannot find any instruction for that. Also, does that mean power to the pump is either on or off when controlled from the relay?
    DFW, TX
    24,502
    Your pump should have come with a separate cable to wire to automation. I think mine had 4 wires but only two were used for my Solartouch. You do not want to wire power to the pump from the relay in the Zodiac, it needs to be wired directly to the breaker. The Zodiac will turn it on and set speed through the controller cable based in settings in the Zodiac.
    sag365's Avatar
    Jan 2015
    Ft. Myers, FL
    42
    OK. Same as the heater. Yes, there is a long cable that came with the pump. Have to find out where to connect in on here!
    Actually, way on the right of the Green Terminal Bar it says "Spare Input" for screws 9 and 10. Wonder if that is it?
    Thanks.
    sag365's Avatar
    Jan 2015
    Ft. Myers, FL
    42
    DFW, TX
    24,502
    Yes, same as the heater. If that spare input is programmable to tell it that a VS pump is connected to it then that is likely the answer. Somewhere in that 80 page manual is probably one sentence that cryptically tells you how to control a VS pump. My experience with pool equipment manuals is that they are not clear and it takes a lot of digging to figure it out. Made worse because most of us rookies only do it once. Good luck.
    Maybe you will get lucky and someone who has a Zodiac will come along and know just what to do.
    Quote Originally Posted by sag365 View Post
    Yeah, there you go.
    sag365's Avatar
    Jan 2015
    Ft. Myers, FL
    42
    Got it!
    Pentair Green > Jandy Yellow
    Pentair Yellow > Jandy Black
    Thanks so much man! Great help. Gonna donate to this site! Been awesome.
    DFW, TX
    24,502
    Sweet! You're welcome.
