Results 1 to 8 of 8
Thread: How early can I open my pool?
    Mar 2015
    Berwyn, IL
    5
    I live in the suburbs of Illinois and currently we just had some of the best weather that I have seen around this time (70-60 degrees). Thanks to the weather I was able to drain all the melted snow and ice off my pool cover. I took a look inside the pool to make sure everything was looking good and there is still a big plate of ice near the center of the inside of the pool and the water surrounding it. Just getting my first pool last year in the fall I am really unexperianced at opening and this is my first time opening I wanted to ask some questions.
    1. When would be the ideal time for me to open my pool? The last I checked my water temp is around the 30-40 degrees.
    2. Since I cleaned off my winter cover should I remove it so the sun can melt the ice inside my pool?
    3. Is there a kit that I need to purchase to help open my pool or will the regular pool maintenance work just fine?
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: How early can I open my pool?
    Welcome to TFP!
    1. Now is a good time if you are sure you're past hard freeze temps.
    2. Yes I would suggest that if you are going to open.
    3. Get the TF100. It's the best there is, and they have true customer service with any sale. Click the link for it in my sig line.
    Enjoy the forum!
    Essential Links:
    Smykowski's Avatar
    Sep 2011
    3,065
    Welcome to the forum! Good to have another Illinoisian join the group!
    Do you have a heater? (Actually, could you put all of your equipment and pool specs in your signature.)
    I'm in the Chicago area as well, and while we're probably out of the woods for a hard freeze, it's going to stay cold at night for a few weeks yet. I'd leave it closed a little longer. The earliest you'll probably swim is early May, and that's only if you heat it. If you're not using a heater, it'll be more like late May or early June. Best way is to get a thermometer in the water, and start opening up when the water temp gets to the high 50s.
    Mar 2015
    Berwyn, IL
    5
    Quote Originally Posted by Smykowski View Post
    No sadly I don't have a heater.
    Sorry about that. When I have time I will update my sig with the spec. Also, thank you for the information, since there is a high chance of snow still dropping I will probably have to wait a while before I open.
    Smykowski's Avatar
    Sep 2011
    3,065
    No problem. If it helps, I opened up around mid-late April the last two years, and no one got in the water until the beginning of June.
    That would be one more bit of advice I'd offer, especially for your first opening. Give yourself plenty of time to get the water balanced. Allow for three weeks between opening and swimming. That will give you plenty of time to get the water clear and balanced. It may (hopefully will) take less, but there's nothing worse than needing the pool ready by a certain date, and it not happening. Or worse, having to tell the kids "No, you can't swim yet" over and over when the weather/water temperature is gorgeous.
    wjr75's Avatar
    Jun 2013
    IL
    836
    We open our pool the first week in may in Illinois. The hot tub gets the most use usually until Memorial Day.
    Inground 22k gallon gunite 15x31 main pool, 15x7 wading pool/sunning deck, hot tub/with overflow (9' octagon with limestone top) & slide NSWG, Aqua Blue Pebble Sheen
    Filter dual cartridge Sta-rite 450sq/ft, TF-100 Test Kit
    Heater Raypak 2100 400k btu cupro-nickel exchanger
    Auto pool cover, Polaris 280 auto pool cleaner, Jandy AqualinkRS8 Remote Control System
    Jun 2011
    Central Iowa
    105
    I'm in Iowa and REALLY want to open or start opening today. This weather has been so great and I thought if we could get the solar cover on now to start using that sunshine to warm the water maybe we could see some swimming in April! I think if we are mindful of these 25-35 degree nighttime temps we can still have and keep the pump running we should be ok.
    I waited too long last spring and it took me a really long time to clean up my water. Don't want a repeat of that!
    27' x 54" AG Morada RTR/19,300 gal/ 1hp-2spd Hayward Power-Flo Matrix/Hayward 256T sand filter
    Apr 2014
    Elk Grove Village, IL
    12
    Also in Illinois, and I'm planning to wait until early May to open. You should get a heater, I'm actually in the process of replacing my 16 year old Jandy with a new Hayward...
