Thread: Jandy Lx high limit flashing how to find and fix
    Jul 2014
    El Dorado Hills, CA
    2
    Sorry for the dumb question. I have a Jandy LX pool heater about 10 years old. The other day when trying to heat the pool, I saw a high limit error. After reading through the manual I think the switches are on the right side of the unit. I can remove the front panel, but I am unsure how to remove the side panel. (if that is even necessary) Any help would be appreciated.
    Re: Jandy Lx high limit flashing how to find and fix
    Bump
    Mar 2015
    Long Beach, CA
    3
    Quote Originally Posted by xpedia View Post
    Your hi limits are located in the header. They open circuit when they get too hot, which only happens when water moves too slowly through the exchanger. This can be caused by a corroded exchanger, but most often by a dirty filter, pump issue, partially closed valve, bypass assembly problem, etc.
    If you have trouble finding them, follow the wires from the temp control assembly. If you flip around your thermostat you'll see a black wire followed by 5 white wires. If the white wire closest to the black wire is white wire 1, white wire 2 and 3 are your hi limits wires (power out and power back).
    Replace both hi limits switches and find and fix your flow issue.
