Results 1 to 12 of 12
Thread: Where is my chlorine going?
    meatloaf's Avatar
    Feb 2008
    Gilbert AZ
    373
    Question Where is my chlorine going?
    My pool was slightly cloudy so I shocked it Thursday night with 2 gallons of 10% chlorine. Yesterday morning the chlorine levels were approx 25 ppm, this morning 0 ppm. Pool is clear but what happened. Thanks (10500 gallons)
    My pool is a 10,500 gallon (420 Sq Ft ) kidney shape. STA-RITE HRPB30, Sand filter 30" 98 GPM, 1 HP Maxi-Glas 2 pump, BBB Method, Taylor K-2005 test kit, 50 Watt 12V low-voltage pond light illuminates the pool at night for a nice soft glow.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,621
    Re: Where is my chlorine going?
    Sounds like an ammonia problem. There was just a thread on this topic if so.
    http://www.troublefreepool.com/threa...nium-breakdown
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    So what else has been going on lately in the pool?
    Did you have an Algae bloom or anything?
    Essential Links:
    meatloaf's Avatar
    Feb 2008
    Gilbert AZ
    373
    Everything was fine until a few days ago.
    Please post a full set of water test results. That will help us figure out what is going on.
    meatloaf's Avatar
    Feb 2008
    Gilbert AZ
    373
    Ch-0, Ph-7.5, TA-70, CYA-30, Ch-650 Temp 72* Thanks, Water is clear now.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Alrighty then.......
    Essential Links:
    30,421
    Well, you have no chlorine in your pool again. There is only one answer....more chlorine.....as much as it takes.
    It is descriptive of ammonia which consumes chlorine very fast and then, when it (ammonia) is all gone by adding chlorine, your chlorine residual will start to show up. Even if it's not ammonia, the fix is still the same.....more chlorine.
    Tell us some history. Did you close the pool this winter? Did you add chlorine over the winter?
    meatloaf's Avatar
    Feb 2008
    Gilbert AZ
    373
    Very little chlorine was added over the winter due to the fact the the water was well below 60*. The pool was still filtered on a daily basis. All was fine till about a week ago when I noticed it was slightly cloudy.
    meatloaf's Avatar
    Feb 2008
    Gilbert AZ
    373
    Will shocking give the same result?
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Well, we don't shock as an event, but rather a process.
    Read about it here: SLAM
    I see your Sig line shows you have a K2005 kit. Do you have another kit, or a FAS DPD chlorine kit?
    Essential Links:
    Casey's Avatar
    SW PA
    10,448
    And what surface do you have in your pool? Vinyl? Pebble? Fiberglass? Please add that as well.
