Results 1 to 13 of 13
Thread: Pool 6 months old - readings
    surferbum's Avatar
    May 2013
    North Scottsdale
    66
    I have a 6 month old shotcrete pool and have been doing all my own maintenance after the PB initial startup. Water has stayed clear and no problems to report.
    The water here in Scottsdale is pretty hard (250-300ppm).
    Latest test results:
    • FC - 5 is target
    • TA - 100-110
    • CH - 400
    • CYA - 35
    • pH - 7.8
    The pH stays solidly at 7.8. About once a month I lower the pH to 7.2 and aerate with water features to gradually reduce the TA. It lowers TA 10-15 ppm and the pH rises (and stops) always around 7.8.
    Two questions:
    1. To lowering the CH much (by replacing water) is tough here in Scottsdale. Should I worry about it?
    2. Any issues if my pool stays at these readings?
    Thanks.
    Shotcrete, Pebble Sheen Aqua Blue interior finish
    Pentair EasyTouch with wireless, IntelliFlo VS+ SVRS pump
    Paramount PV3 infloor cleaner & MDX3 drain, Heliocol solar heating
    Perimeter 94', 13866 gallons, Max. dimensions 33' x 14, depth 3'6"-5'0", Baja entry & knife-edge end.
    Casey's Avatar
    SW PA
    10,446
    Re: Pool 6 months old - readings
    The only way to lower CH there is with fresh rain water or looking into the osmosis which can be expensive. Your CH isn't bad but you should try and keep your pH down around 7.2 so that it doesn't start clouding or causing problems with your CH if you have to refill with your tap and the CH goes up. Also, you need to raise your CYA to the very least 50 in that hot Arizona Sun.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Quote Originally Posted by surferbum View Post
    • FC - 5 is target
    • TA - 100-110
    • CH - 400
    • CYA - 35
    • pH - 7.8
    Two questions:
    Thanks.
    Currently, not at all with the CH. It's toward to higher side, but 400 CH is easily manageable. Depending on how much CH your fill water has determines how fast that increases in you pool.
    Keep an eye on it, along with managing your pH carefully and not letting it get high (above 7.6) if you can help it. I prefer a little safety factor and would want this to be my high limit. Certainly don't let it remain above 7.8.
    TA is a little high, but I imagine your fill water has a lot, so it will keep you on a course of faster rising pH when you have this situation. Just watch the pH and keep it in line.
    Essential Links:
    30,421
    Nothing earth-shaking. Casey's advice to raise CYA to 60 is the most important change I would nake. Next, keep a pretty close eye on CH and pH but you seem to be doing that just right already.
    What's the CH of your fill water?
    surferbum's Avatar
    May 2013
    North Scottsdale
    66
    It is.
    30,421
    Sorry I missed that CH. I would suggest that you are in pretty good shape other than the suggestions above.
    surferbum's Avatar
    May 2013
    North Scottsdale
    66
    Quote Originally Posted by Casey View Post
    I'll make that my goal.
    surferbum's Avatar
    May 2013
    North Scottsdale
    66
    I hired a neighbor's pool service for my pool while I was out of town for 3 weeks. When I tested the pool when I returned there were some readings which are outside the range recommended here (in parenthesis). Should I take any action to change these readings?
    pH (7.5-7.8) 7.5
    TA (70-90+) 50
    CYA (30-50) 70
    CH (250-350) 400 [our tap water is 350]
    surferbum's Avatar
    May 2013
    North Scottsdale
    66
    pH (7.5-7.8) 7.5
    TA (70-90+) 50
    CYA (30-50) 70
    Don't know if this was seen since website problems.
    Jan 2014
    Buckeye AZ
    807
    looks like they just threw in some tabs while you were gone? or had you raised the CYA before you left?
    10,500 gal IG, Topaz Pebble, auto-level
    Hayward DE filter, 2HP Ecostar VSP, ProLogic PS-4, GVA actuators
    Cal Pools Wave Force Plus (wall return jets plus 2 floor pop-ups), Venturi Skimmer
    Water sheer, 2 wok pots, bubbler stem on the baja step
    ColorLogic Mutlicolor LED lamp. Taylor 2006+speed stir
    surferbum's Avatar
    May 2013
    North Scottsdale
    66
    My pH always seems to go to 7.8 and stay there. I add acid and it temporarily goes to 7.2/7.3 but moves back to 7.8. Not too worried about it hanging around 7.7/7.8. Anyone have similar situation and remedies?
    Mar 2007
    San Rafael, CA USA
    12,082
    That is normal and not a problem. A higher TA or a lower pH causes more carbon dioxide outgassing and that has the pH rise faster. Stop trying to lower the pH so much, certainly not below 7.5. If it's fairly stable at 7.8, then leave it there. If your TA or CH are high and you are worried about calcium carbonate scaling, you can lower your TA instead. If you venture close to or beyond the edges of the Recommended Levels, then you can calculate the CSI in PoolMath to see if it's too high.
    The only risk of a high pH (with other levels balanced accordingly to not have the CSI too high) is metal staining. If you don't have metals in your water, then this isn't a problem.
    surferbum's Avatar
    May 2013
    North Scottsdale
    66
    Quote Originally Posted by chem geek View Post
    Thanks.
