Thread: Dumping SWP
    Dumping SWP
    I am about to dump the water from my AGP, I have it set up with a Chlorine Generator (Intex). I live on an acreage so i need to dump the water out on to the ground. My question is "will this hurt the trees? It seems to be that the chlorine is already hard on the grass. The pool has about 23,000 L.
    If i can not dump into the trees (ground) what do i do with the water?
    16x32 Hydra Liner, Hayward 24" Pro Sand Filter, WhisperFlo 1HP Pump, Hayward CL200, AquaChem Test Kit =[
    Re: Dumping SWP
    Welcome to TFP!
    Most plants are fine with a little salt. There are some salt sensitive plants, but you would normally know if you have sensitive plants. Salt is a bit more of a risk in arid areas, where it can build up in the soil over time. Usually the only issue is running the water slowly enough to avoid erosion.
