Results 1 to 10 of 10
Thread: Patio and Yard Sound System
    Jdhockey526's Avatar
    Jun 2014
    Chino Hills, CA
    3
    Hi all - wanting some advice on how to set this up. Here's what I'm going for:
    Patio (zone 1):
    TV with decent sound system and ability to play music
    5.1
    Pool/Spa (zone 2):
    Ability to play music or sound from TV (i.e. game is on)
    4 patio mounted speakers pointing at pool plus a rock speaker near the spa
    BBQ (zone 3):
    2 speakers mounted on the BBQ patio cover
    This is all new construction so there are no limitations on wiring etc. I would only want one music source meaning I wouldn't want my kids music at the spa and my music at the BBQ (my house, my music). I would like to have the ability to adjust volume at the BBQ and pool/spa zones as well. Thanks in advance.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,517
    Re: Patio and Yard Sound System
    Zone 1
    sonos playbar and optional subwoofer if you want it.
    Zone 2 and 3
    As many sonos playones or playthrees as you need to fill out the sound. I doubt you would need more than one or two at each location. One playthree or 2 playones will create a large soundstage.
    And add a boost with an ethernet cable to your router. This will allow you to play any music anywhere or play the tv sound anywhere. Also, you could play different music in each zone. Independent volume control or synched volume control. All controlled from as many iphones, androids, tabs as you want to load the app on. Sources can be ipod, computer music library, googleplay, jango, pandora, slacker, etc. No speaker wiring needed just power at each location.
    And you can unplug them and take them inside or anywhere in your wifi area plug them in and listen to music anywhere you want.
    Mod Squad woodyp's Avatar
    Apr 2010
    East Texas
    9,659
    Welcome to the forum. I'm sure the audio gurus will be along shortly! Might help if you post a pic of the overall area or give some dimensions on how far apart all these areas are.
    DFW, TX
    24,517
    Or you could copy martinkennedy's superamazingoutdoorconcertsoundsytem found here:
    http://www.troublefreepool.com/threa...Poolside-sound
    And I can control it all from my I-Phone. You can see the area I had to cover in" New build in south Texas" thread
    txnole's Avatar
    Aug 2014
    Amelia Island, FL
    544
    Sonos Connect Amp is a great addition to drive speakers and add smartphone connectivity/control. We did that out back. If you are going to have a head unit outdoors, consider a marine unit (as you would install on a boat). You can get some really strong head units in a small form factor... plus they are made to be weatherproof.
    COMPLETED BUILD THREAD - 15'x29' rectangular offset shotcrete pool; 14,100 gal; 5'x7' raised spa with 400k btu fire feature; 7' spillover; 25' leuder stone raised bond wall w/waterfall; Pentair SWG; Pentair VS (pool); Pentair 3/4hp feature pump; 1hp spa blower; Pentair Cartridge filter; Pentair “Easy Touch 8” wireless; Dolphin Oasis Z5 robot; Solar Hydronics iSwim solar panels; Mansard Screen Enclosure; walnut travertine deck; 1 very happy kiddo.
    Ga mike's Avatar
    Mar 2014
    Georgia
    85
    I use apple express plugged into three zones on top of cable box with 12 zone amp. I can put sound about anywhere with my phone.
    20x45x32x18 L Shaped vinyl Pool
    Pentair Superflo 1.5 vs pump
    Pentair t100 filter
    I 60 cell
    Z7What's Avatar
    Mar 2015
    New Orleans Area
    141
    Quote Originally Posted by Jdhockey526 View Post
    Patio (zone 1):
    5.1
    Pool/Spa (zone 2):
    BBQ (zone 3):
    I just wired a friends new construction home with a system from HTD.com
    Its has 6 different zones, allows for 6 different sources, allows for independent volume control for each zone, each zone can have up to 4 speakers and it also has the ability to have a sub zones that the volume can be controlled differently from the zone that feeds it, but you are forced to listen to the same source that zone is listening too. It does NOT have the ability to do 5.1. Cant say for sure if it has the ability to have a subwoofer either.
    They have digital keypads or analog keypads, there is also a optional Ipad interface that allows you to control the entire system via your iPhone. The keypads connect to the Amp/Controller via Cat5/6. Its very simple to install as well but if you go with this route don't listen to HTD about how they have you wire it PM me and ill tell you how to do it. Ended up wasting alot of speaker wire during it there way. I ended up redoing it my way and it not only made for a much easier install, it made it very neat, easy to access and saved roughly 150' of speaker wire doing it my way. If the HTD system is out of the price range Monoprice.com also has a WHA(Whole Home Audio) system you can get.
    Just a option...
    Wayne
    24'X54" Round 15,000 Gallon Pool
    Pentair SD-60 Sand Filter With 1.5HP Pump & Center Floor Drain
    Lil' Shark Vacuum With Leaf Canister
    New TFPC User And Couldn't Be Happier
    Pool School + Test Kit + Pool Math = A Perfect Trouble Free Pool
    Jun 2014
    Chino Hills, CA
    3
    Thanks for the replies. I've never used Sonos so I did some homework. Looks like a great idea and much simplified installation. I also like that if I need to move or add speakers them to modify the sound it's a simple task.
    Dec 2009
    Central Massachusetts
    2,690
    I have a Russound whole house system paired with Casa Tunes. I have key pads in every room and can also control it with an iPhone App.
    14,000 gallon IG, Vinyl. Hayward 3/4 hp superpump, Penatair IC40 SWCG, Pentair automation, Hayward sand filter, Aqua Comfort heat pump, Hayward 400k Lo-Nox LP heater.
