Results 1 to 14 of 14
Thread: filter pressure dropping?
    Mar 2015
    mobile al
    16
    Newbie pool owner here. Im slamming pool for the first time. Its very green. Ive ran the pump/filter for hours before and had no problem but now my pressure is dropping from 20 psi (where it usually is) to almost nothing. Ive wasted and backwashed and that helps for abt 15 min then back to around 5psi. Any ideas?
    35000 gal vinyl inground. Sand filter. Age unknown
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: filter pressure dropping?
    Welcome to TFP Phillip!
    Sorry to answer you with a question, but what is your starting pressure from clean?
    Essential Links:
    Charlie_R's Avatar
    May 2013
    Mexico, MO
    2,156
    Are there any bubbles in your pump basket? If there is, you've got a suction side leak.
    What else can you tell us about your pool equipment?
    Mar 2015
    mobile al
    16
    My clean pressure is usually around 18psi. I know that the motor is a 1hp. The equimpment is old and wasnt maintained very well by the previous owner. Most of the stickers are gone from the equimpment. Sorry i dont have any more info. No bubbles in the skimmer basket but i do have bubbles coming from one of my jets. There is a hairline crack in the clear lid on the pump cap that is sucking a little air. Not much though
    Mar 2015
    mobile al
    16
    Could I have a clogged return pipe somewhere?
    markmc's Avatar
    Jun 2013
    Sumter, SC
    7
    I just found my pressure dropping during the slam process. Something I overlooked was the pump filter basket since I normally do this weekly during the season. It was clogged full of debris from the pollinating trees hindering the pump, hence the pressure drop. Cleaned it and back to normal. Might be something easy to check.
    13,593 ga. Celebration Disitnction LX 24' Round AG, Pentair SD40 Sand Filter, Pentair Dynamo 1.5 hp pump, Installed 7/8/14, TF-100 test kit
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Quote Originally Posted by phillipwyse View Post
    You need to replace it ASAP no matter how tiny. This is really important.
    A clogged return would give the opposite issue. As mark says above, check that too.
    Essential Links:
    Mar 2015
    mobile al
    16
    Are you referring to the skimmer basket Mark? Im not sure of another one if you arent.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    He means the pump filter basket inside the pump housing.
    Essential Links:
    markmc's Avatar
    Jun 2013
    Sumter, SC
    7
    The one I'm referring to is under the clear plastic cap on your pump. It normally doesn't fill up as quickly as the skimmer basket, but if it is, that might be the issue, along with the crack you mentioned.
    30,431
    As Patrick_B says, if you are sucking air, your system will not work. Replace that Pump Strainer lid. If you keep it dry, you can temporarily seal it with duct tape.
    Report back the results.
    Mar 2015
    mobile al
    16
    Wow that did it guys. I didnt know there was a filter there. I feel like an idiot. Definetly not the first time ive felt that way. Thanks for the help!
    markmc's Avatar
    Jun 2013
    Sumter, SC
    7
    Glad we could help!
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Good deal, glad you got it sorted!!
    Essential Links:
