Results 1 to 18 of 18
Thread: Going w/Liquid Chlorine Exclusively. Anyone Else w/Me?
    Jun 2014
    Chandler, Arizona
    88
    Last year I used a combination of liquid chlorine and an overuse of trichlor tablets. Not surprising to most in this community, my CYA was at 100 when I began preparing my pool for spring temperatures, resulting in having to drain half my pool. Current CYA is 55-60 and I'm happy to say I'm divorced from trichlor forever.
    The question I have for those who have a similarly-sized pool located in the Southwest and use liquid chlorine exclusively is: What do you spend monthly on LC? I purchase a 10% concentration at a local pool store for $8.00, which is a box including two 1-gallon containers.
    28k gallon in-ground pebbletec pool w/waterfall and grotto feature
    Triton II sand filter
    "The Pool Cleaner" 4-wheel vacuum
    1.5hp main pump; 1.5hp water feature pump
    Taylor K2006 test kit
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Going w/Liquid Chlorine Exclusively. Anyone Else w/Me?
    Sure, that's what all of us do here for the most part. You still need Cya in there too, though. If not, you'll lose all the FC you put in each day. I like most, add the Cya separately to keep strict control over that.
    It's fine to use pucks in the beginning, or while you are away, just as long as you keep your Cya level under control.
    I think you should figure about 80 Oz per day of 10% in your pool, depending on use. It may be off a little, as all pools are different in terms of sunlight exposure, use and Cya level. If that place doesn't move a lot of liquid, it may be a good bit weaker than 10% when you get it.
    You'll just have to see how it goes, but this will get you close.
    Essential Links:
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Everyone is going to spend a little differently for FC.
    FC is measured in ppm, and how much chlorine you need to be at x ppm of FC directly related to the pool volume.
    The Loss factors are
    What is the CYA level
    How much direct sun each day the pool gets
    How many leaves and other organcis fall in the pool and how long does it stay there etc...
    But generally, speaking, you can expect anywhere from 2 to 4 ppm loss each day.
    If you really want to figure out your expected costs, you can use pool math and create a scenario where you need to add x amount liquid chlorine
    and then use the Chlorine Price calculator to figure out the cost of x ppm.
    http://poncatechsquad.com/Dan/Chlorine/
    http://www.troublefreepool.com/calc.html
    Divin Dave,
    Apr 2013
    Sanford, Florida
    32
    I've been using nothing but liquid for the past few years. The regular stuff here is 10.5% and comes in 2.5 gallon refillable jugs that cost about $4 each to refill. I normally tear through one a week or more if there is heavy rain or usage.
    23,000 gallons, in-ground, gunite
    Hayward C1200 cartridge filter system
    Pentair 1HP pump
    30,421
    The TFPC method is not always about the cheapest way (although liquid FC is normally the cheapest source) but rather teaches you to make your decision based on a variety of factors and then knowing what to do about the best way to proceed.
    Your FC price sounds a bit high but you will likely find cheaper. Importantly, you will always have the great feeling of managing and controlling your pool rather than the other way around.
    Smykowski's Avatar
    Sep 2011
    3,065
    The aggregate cost of the TFPC method is usually cheaper because in the end, you don't pay for unnecessary chemicals. Also, with the chemicals you do have to buy, you're not paying ridiculous prices for fancy pool chemical brand names.
    30,421
    Only many, many thousands!
    Jun 2014
    Chandler, Arizona
    88
    Looking at Pool Math there is a recommended range of 30-80, which is large. I'm at 55. How does one determine the sweet spot for CYA?
    And what type of stabilizer is best? There are so many on the market nowadays. And I'm now petrified to use trichlor pucks.
    30,421
    Stay at 55 and observe how much FC loss you experience. I would guess that's about the right amount for AZ climate.
    All CYA stabilizer is the same......brands don't matter
    Nov 2013
    Phoenix, AZ
    15
    I'm with ya.
    I buy 12.5% at my local pool store and pay $14 for 4 gallons around once a week.
    50,000 gallon, IG, pebble, Triton II sand filter, Hayward EchoStar VS pump, Dolphin M5
    Mar 2015
    Southern California
    25
    Quote Originally Posted by asusundevil View Post
    From one newbie to another....
    If the pool store chlorine is actually 10% not 12.5% for $8, then you are better off getting it elsewhere.
    I get mine from Lowes usually.
    I checked the Chandler AZ lowes and they sell it for $6.86. 2 gal box of 10%
    *** If you snoop around online you can find a 10% off coupon code for lowes. Then order it for pickup.
    Make sure you check the dates. Sometimes they pull out an old pallet of the stuff.
    38,295
    Look for a HASA dealer near you. They will have fresher and higher strength chlorine available to buy in bulk ... even cheaper than Lowes.
    See: http://www.troublefreepool.com/threa...iquid-Chlorine
    Mar 2015
    Southern California
    25
    Thanks I didnt even know about that. Need to spend more time on the site I guess.
    Just called. My local Hasa dealer has it for $19.26 for 4 gals of 12.5%
    But they told me not to run CYA between 30-50, suggested 90 cya level for Socal....
    38,295
    90ppm is excessive. I would ignore that.
    Is the $19.26 the refill price or the initial price to get the jugs? That seems a little high if it is the refill price ... Lowe's might be cheaper according to the calculator: http://poncatechsquad.com/dan/chlorine/
    mrcarcrazy's Avatar
    Jan 2014
    Odessa, TX
    977
    Last year I spent so little on Chlorine that I didn't even notice it on the budget. I love the TFPC method.
    IG gunite/plaster pool/spa Started 1/17/14, Plastered 5/16/14
    Size: 12'-21'x39' free form, depth ranging from 4' to 7, attached 6 person spa with spillover.
    Equipment: Whisperflo 2hp pump, Pentair 30" sand filter, Pentair Mastertemp 400k BTU heater, 1hp Whisperflo for waterfalls, and a blower for spa floor
    Mar 2015
    Southern California
    25
    I just called back to confirm the Hasa Chlorine.
    Refill price $19.26 for 4 gals
    Deposit on each 1 gal bottle is $0.5
    Deposit on the carrying case is $2.00
    Looks like Lowes is still better since they honor my 10% Veterans discount every time I go in.
    38,295
    Wow, surprised that the Hasa chlorine is 38% more expensive for you than it is here.
    jrs_diesel's Avatar
    Aug 2014
    League City, TX
    215
    Me too, I regularly get buy the HASA 12.5% from my pool store for $17.99 here in Texas. Buying the first case was $2 more (deposit).
    I am also a liquid chlorine user ever since we moved into our house. Previous owners had used trichlor/dichlor and cal-hypo. The CYA level was 140 and the CH was 700. Drained 16,000 gallons, refilled, and the water has great since then.
    J.R.
    20K IG gunnite pool
    2HP Hayward single speed pump
    Cartridge filter
