Results 1 to 11 of 11
Thread: Pool Pillows
    Jul 2008
    Bucyrus, Ohio
    108
    Pool Pillows
    Can someone please tell me how many pool pillows I would need for a 15' AG pool?
    Overwhelmed
    Pool size: 15' X 48" AG vinyl liner, 5300 gallons, Hayward S166T filter and 1hp pump
    searayboater's Avatar
    Jul 2008
    The Great State of Texas
    65
    Re: Pool Pillows
    You need one. Don't inflate it until is is firm. The pillow needs to be able to "crush" to take up for the expanding ice in the pool, if ice forms. I use one pillow tethered in the center of an 18' AG.
    18' AG Pool, 6900 gallons, 55 sq. ft. Hayward Easy Clear Cartridge Filter, 1hp Power Flow LX Pump, North Texas
    Jul 2008
    Bucyrus, Ohio
    108
    Re: Pool Pillows
    should I get a 4X4 or do I need a bigger one?
    Overwhelmed
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Pool Pillows
    That should be fine, I use a 4 X 5 and I have a 24'.
    Mar 2007
    Coastalish 'down easter'
    4,160
    Re: Pool Pillows
    I don't want to disagree with you Ann, but - as with filters, I think 'bigger is better', a couple bucks more for a larger pillow will better support the cover and help keep the water / debris more reachable.
    Of course I've never owned a pool and the largest majority of those I've worked on were not AG pools - so take this advice with a grain of salt
    Luv& Luk
    -Ted
    Jul 2008
    Bucyrus, Ohio
    108
    Re: Pool Pillows
    I ordered a 4X4 Round pillow not the square one, should I change it to a square one? I just ask cause I dont see anywhere on the rounds to attach it to anything and maybe I am wrong maybe they do have gammets to attach to, if someone knows please let me know.
    Thanks
    Overwhelmed
    Cassiopeia's Avatar
    Jun 2008
    Tampa Bay FL
    46
    Re: Pool Pillows
    I don't want to sound uninformed....but what is a pool pillow? And when/why does a pool owner need one? Sounds like something you need for "winterizing" a pool? I guess I don't need that in FL?
    15' ROUND, 52" AG
    Newbie at pool ownership!
    Jul 2008
    Bucyrus, Ohio
    108
    Re: Pool Pillows
    Yes a pool pillow is used for winterization. You put it under your winter cover to help absorb some of the ice expansion that goes on. Beyond that I honestly dont know that it does anything else persay.
    I am still wondering if Round does the same thing as Square?
    Overwhelmed
    11,969
    Re: Pool Pillows
    Quote Originally Posted by waste
    You can disagree any time you want.
    I've used a 4 X 5 for the last 6 closings, my pool is frozen solid for much of Jan/feb, I've had no issues. Since youre pool is slightly smaller than mine, you would technically be going "bigger/better" to touch on what Ted said.
    I don't know if it makes a difference, round or square.
    LOL a pool pillow in Florida! Must be nice not to have to winterize. But then we don't have hurricanes....
    Re: Pool Pillows
    I closed my pool with a brand new pool pillow, but it must have deftlated becasue I do not see it anymore. the pool is pretty frozen. what do I need to worry about?
    Is there anything I can do now or is there something I should do in the spring when it gets warmer, but not warm enough to actually open the pool.
    Thanks for any information you can give.
    DSW0000
    Mar 2007
    4,160
    Re: Pool Pillows
    Deaniew, welcome to TFP!!
    The pillow had already done it's job (what they do is support the cover and keep the water on the cover from stressing the top rail too much, which the ice is doing now ) When you start to thaw try to pump or siphon off as much water as you can from the cover to reduce the stress on the walls and try to keep up with rain collecting on the cover.
    I wouldn't worry about it 8)
    While we're all waiting for spring you might want to do a little reading here (Pool School is a great place to start) so you get an idea of what we're talking about here and be all ready to open the pool in the spring!
    If you have more questions - ask away - we're here to help (& it's a little sow this time of year )
    Again welcome to TFP!!
    Luv& Luk
    -Ted
