Thread: First numbers from the Taylor 2006
    Defgufman's Avatar
    Mar 2015
    Savannah GA
    584
    Cya 60
    Ph 7.4
    Ta 90
    Ch 80
    Fc 4.2
    Cc .6
    Borates 50
    Looks like the PoolFrog was putting a lot of CYA in the pool, but now he's empty.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: First numbers from the Taylor 2006
    Ok good!
    A little adjustment needed there, and can you please add you pool info to your sig line?
    How does the pool look, and what is your fill water CH level? Depending on the type of pool you have, you may want to add some CH to it.
    Essential Links:
    Defgufman's Avatar
    Mar 2015
    Savannah GA
    584
    I'll edit my signature when I can get on my home computer. The pool is vinyl and the water is crystal clear.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Great!
    I assume your fill CH is very low. That is fine though, many of us have the opposite problem. Easier to fix than having too much.
    Essential Links:
