Thread: Hard White/Yellow Milky Stuff
    Jan 2013
    Friendswood, TX
    320
    Hey guys... Found this today under my waterfall.
    It wouldn't come off with a brush, haven't hit it with acid yet. It is smooth, shiny, and only in one spot.
    Thoughts?
    ~Paul
    19x40 IG including 10' BE, 18,000 gal, plaster, 48 SF DE, 1.5HP pump, AquaPure SWCG, Ozonejoe 30MR, Rockwaterfall, LED light, TF-100 Fill date 11/21/2014
    My ODK Build | My Pool Build | If You're From Texas Vote Here
    30,432
    Re: Hard White/Yellow Milky Stuff
    Remove it with acid....start with 3:1 water/muriatic and then go 2:1 or more until it comes off. Rinse right away with clean water.
    It will come back sooner or later....nothing you can do.
    Jan 2013
    Friendswood, TX
    320
    Thanks! Any idea what it is? It's above the waterline and almost never gets wet.
    ~Paul
    30,432
    It's called efflorescence. moisture from behind the rock migrates onto the surface where it evaporates leaving behind the minerals it has carried with it.
