Results 1 to 7 of 7
Thread: imPower and Marathon Electric pumps
    Mar 2015
    St Augustine
    5
    Just found out that IMPower went bankrupt. So I have a 28 month old $550 pump....I mean paperweight. Run light is green, no error codes, motor doesn't run. I have turned off the breaker for 24 hours, no luck. Note I had error codes a couple of times in the past, the breaker fix worked then. All the buttons on the control panel are dead, non-functional. All the elec savings way outweighed by the cost of the pump.
    And Pinch a Penny is still selling these locally.....
    Took it to an electric motor shop who said that the windings test OK, but beyond that they can't tell. Would have to send the panel off to be tested and repaired, 10 days and N dollars......
    Will replace this with either a single speed or something similar, and stick this on eBay and also look for another one on eBay and start switching parts around.
    Yep, not a happy camper right now, cost me $500+ and so it cost me money rather than the other way around.
    Does anyone have any other suggestions?
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: imPower and Marathon Electric pumps
    Welcome to TFP!
    Bankruptcy doesn't necessarily mean they are out of business. Have you been in touch with the company?
    Mar 2015
    St Augustine
    5
    Local motor shop as well as Pinch a Penny have given up getting to anyone, and I have gotten nowhere so far either. Good point though about the bankruptcy....
    The 1-800 number in their manual seems to be directed to another company right now,
    bobodaclown's Avatar
    Apr 2011
    Murrieta, CA
    2,360
    If you're going to replace the motor, use a 2-speed. Any water features?
    Mar 2015
    St Augustine
    5
    Quote Originally Posted by bobodaclown View Post
    Do you mean like waterfalls etc? Yes 3 across a back wall of the pool. Pool is approx 11k gallons, 25x13.
    Or did you mean something else?
    I am going to Pinch a Penny tonight and talk about alternatives including a 2 speed for $409 vs a single speed for about $250
    Thanks!
    Apr 2011
    Murrieta, CA
    2,360
    You can replace just the motor and keep the wet end
    Mar 2015
    St Augustine
    5
    Yes, looking at a V Green 165 Centurion (I think), 549 with 3 variable speeds. I was offered the last impower in the store for $300 cash. Thought about it but declined in the end, will list he old motor unit on ebay and at the same time keep a search running for a similar one with bad motor
