Page 1 of 3 123 LastLast
Results 1 to 20 of 56
Thread: Pool, Spa & Kitchen Build - Houston, Texas Excavation Date 3-23-15
    Hey all,
    Finally got a excavation date of 3/23. Gunite is set for 3/25 - Going to be a busy week!
    Pool Info
    POOL
    POOL SIZE: 15’ X 49’
    PERIMETER: 144 LN.FT.
    AREA: 773 SQ.FT.
    BENCH : 2
    STEPS : 2
    DEPTH : 3 ’ – 6 – 3 ’
    TILE : 2” X 2” Frost Proof Decorative Tile. Tile markers on steps and benches.
    COPING : 1’ of TRAVERTINE AROUND ENTIRE POOL
    PLASTER : PEBBLE TEC/PEBBLE SHEE – TIER # 1
    DECK : 1000 SQ.FT. OF TRAVERTINE TILE (CEMENT BASE), VERSAILLE PATTERN, WITH ALL DRAINAGE
    STRUCTURE INFORMATION
    LIFETIME GUNITE SHELL WARRANTY THAT IS TRANSFERABLE TO FUTURE OWNER.
    STEEL REINFORCEMENT: 12”x18” Bond Beam – 4 Bars #4 (1/2”) continuous. Walls and Floor - #3(3/8”) 8” on center.
    GUNITE : Walls and Floor minimum 9” thick. Gunite Bond Beam 12” x 18”
    PLUMBING : 40 LN.FT. Heavy wall Schedule 40 PVC pipe size 2” for all out lines and 1 ” in return lines. Gas Line connection if required.
    SKIMMERS: 2
    RETURNS: 10
    MAIN DRAINS: 2
    POOL EQUIPMENT
    FILTER: 525SF CARTRIDGE
    CHLORINATOR : YES – INLINE
    OZONATOR : ULTRAPURE
    PUMP : ECOSTAR-VARIABLE
    POOL LIGHT : 2 COLORLOGIC (LED)
    CLEANER : POOL VAC ULTRA
    SPA
    SIZE :TRIANGLE SPA 12’ X 8 ’ – RAISED 18” – 13 FT. LONG SPILLWAY – ALL EXTERIOR COVERED WITH FLAGSTONE LEDGESTONE.
    SPA PLUMBING
    JETS : 8 (4 ARE ROTATING)
    MAIN DRAINS : 2
    RETURNS : 8
    SPA EQUIPMENT
    HEATER : 400,000 BTU’S
    BLOWER : 2 HP
    SPA LIGHT : 1 COLORLOGIC
    CONTROL SYSTEM : PROLOGIC PS-8 + AQUACONNECT REMOTE POOL MANAGEMENT SYSTEM + AQUAPOD REMOTE CONTROL
    TANNING SHELF : 12’ X 8’ INCLUDES 1 LED BUBBLER IN SHELF+ 3 LED BUBBLERS ON BENCHES
    RAISED WALLS : 24 FT. LONG 18” RAISED + 27 FT. LONG 12” RAISED. FRONT COVERED WITH LEDGESTONE. INCLUDES 4 – 48” SHEER DESCENTS + 1 HP TRISTAR PUMP.
    OUTDOOR KITCHEN & BATHROOM:
    SIZE : 581SQ.FT. (25 ’ X 29 ’)
    HEIGHT : 10’ HIGH – CEILING 9’ HIGH
    BUILT TO HURRICANE CODE STEEL CORNER BRACKETS / HURRICANE CLIPS /BEAMS STRAPPED AND BOLTED TO SUPPORT COLUMNS.
    FRAMING FRAMING ON 16” CENTERS / ” LAG BOLTS IN LEDGER – ZIG ZAG PATTERN / NOTCHED BEAM TO SUPPORT POSTS / DOUBLE STACKED 2” LUMBER FOR 2" x 6" CEILING JOISTS AND RAFTERS / PITCH 7/12.
    ROOFING MATERIALS HIGHEST QUALITY 30 YEAR SHINGLES / 30 LB FELT PAPER / GALVANIZED ROOFING NAILS / GALVANIZED DRIP EDGE / 1/2” OSB ROOF SHEATHING OR 5/8” T&G FOR OPEN RAFTER UNITS
    Dec 2014
    Frisco/Texas
    45
    Re: Pool, Spa & Kitchen Build - Houston, Texas Excavation Date 3-23-15
    Wow, really impressive looking. Can't wait to see the pics.
    Good luck with the weather. We've been waiting for plaster for almost 3 weeks here in North Dallas area.
    Keep posting pics
    It's been wet here as well. First streak of dry weather and she lined up excavation and gunite. Hopefully it stays that way.
    I'm setting up some cameras for a time lapse of the build. I'll be sure to take lots of pics as it helped me watching others with my build/selections.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,512
    That is going to be a good one!
    Oct 2014
    Austin/TX
    27
    If I were doing it all over again, I'd ask for steps with no more than an 8-inch riser. My pool has 12-inch risers, which are very steep. I can't imagine small children or seniors easily navigating the steps. I'd also ask for a step in the spa, as the distance from the coping to the bench in the spa is especially steep... Relatively minor changes but it keeps the pool easily accessible, a consideration for resale and guests.
    Recommend 2.5" pipes to/from the pool, and use as many direct/independent runs as possible, especially for features like bubblers and sheers. Two drains in the spa should each come back to the equipment pad independently, allowing future options for two different pumps. Spa jets should be plumbed in a loop. With eight jets, you may want to consider 2.5" plumbing to support high flow rates for the jets. Pool returns should be plumbed in a loop. I found my spa was setup correctly in a loop (and second loop above that for the blower), but the pool was done open, like a horseshoe, not a loop, which tends to send the water back with uneven flows at the far ports versus the near ports.
    15K gal, IG gunite, NPT Tropics Blue Mini-Pebble, Hayward equipment, cartridge filter, SWG, OK coping, under construction
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,011
    Congrats Erik!
    Good luck with your build!
    Divin Dave,
    TW Pool's Avatar
    Mar 2015
    The Woodlands, Texas
    79
    Great looking pool! Do you know who your subs are yet?
    Pool is marked off and ready to dig - bobcat broke down and they couldn't get it fixed. New day tomorrow! Hopefully have some pica of a hole to show you then.
    I'll post some more pics soon.
    Rebar & plumbing tomorrow - Gunite Thursday!.
    Texasrebel's Avatar
    Mar 2015
    Conroe/houston
    28
    Nice ...I'm north of you in conroe and they started the dig on mine today. Did not finish so I hope it will get done tomorrow. Looks good.
    Re: Pool, Spa &amp; Kitchen Build - Houston, Texas Excavation Date 3-23-15
    Sorry. I've been slacking with pictures! I usually take a million - but have been swamped with work.
    I'll be sure to capture plenty of plumbing pics (tomorrow).
    So far the builder has been great. Really impressed!
    Junior's Rebar
    Titan Gunite
    I didn't see who did the excavation - wasn't home unfortunately.
    Casey's Avatar
    SW PA
    10,457
    Very nice!
    So tile decision is final
    Travertine Decking & Coping
    Travertine Ledge stone for Walls
    Noble Glass Tile for spillway and spa
    The pebbletec is Blue Granite
    DFW, TX
    24,512
    Fantastic color choices. Love the blue glass tiles and Blue Granite was our second choice for the pebble. Took us a while to decide which.
    TW Pool's Avatar
    Mar 2015
    79
    Looking great so far!
    Casey's Avatar
    SW PA
    10,457
    Very nice selection!
    some pics of the plumbing and equipment.
    not very exciting but progress.
    Travertine should be here tomorrow - coping and tile Friday hopefully.
    Texasrebel's Avatar
    Mar 2015
    Conroe/houston
    28
    You're screwed if anything ever leaks. No way to just cut one pipe they should have left at least one inch for repair purposes a few inches would be ideal. I hate fixing plumbing that's been done this way it gets expensive.
    IG gunite/plaster 9,200 gals-with 7x7x1-1/2 splash pad with bubblers.
    3/4 hp hayward super pump for bubbler and water fall-1 hp hayward super pump for filtration
    24" hayward sand filter.
  20. Back To Top    #20
    not to mention the fact that it will be under a travertine deck/patio.
    It's like worrying about the plumbing in my concrete slab - anything is possible.
