Thread: Brilliant....
    Defgufman's Avatar
    Mar 2015
    Savannah GA
    584
    Brilliant....
    I am easily amused and ran out and bought some knee high nylons after seeing it here on one of the posts about skimmer socks. It has worked great and is grabbing all the the tree pollin landing in my pool. After seeing that, I added one to my Polaris and that thing got all the fine sand in my pool floor. Looks like the vacuum will be lonely this summer.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,002
    Re: Brilliant....
    we know all sorts of neat tricks!
    I have only used a manual vacuum 3 times. I would be hard pressed to remember how to get the vacuum hose primed!
    Divin Dave,
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Re: Brilliant....
    I don't even own a vacuum!!
    Be a little careful with the skimmer socks/nylons, I've had them clog up nearly completely and restrict water flow to the pump. If you have a valve that controls skimmer/main drain mix then leave 25% or so of main drain flow. That definitely does a great job of cleaning out the pollen and little tree stuff.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Brilliant....
    Skimmer "socks" rule. Love em! I buy them at pool builder supplier cheap and use them for a month then toss em. I like those much better than stockings, but what I love most is not cleaning the filter basket and pump basket so much. They are great.
    Essential Links:
