Thread: I'm finally getting my CYA down a little at a time
    sgt173's Avatar
    Feb 2015
    Parrish,FL
    63
    After 4 times at draining off 6-8 inches of water at a time.
    I'm finally getting my CYA down closer to normal and the rest of them balanced out too.
    The last few test with my new R0013 regent and I think I'm at about 60 now.I started at like 190 when I moved in here!!
    The old regent that came with the kit I got gave me a reading that was a lot different than when I tested with the new stuff.
    Now that I got enough to R-0013 to do the full test instead of the extended one. I can play with it more to get a better idea of how to read it. It really seems to matter what kind of light you stand in don't it?
    I'm getting use to using my Taylor K2006 kit practice makes perfect and someday I wont even have to look at the instructions maybe
    Yesterdays test results:
    FC 7
    PH 7.6
    TA 100
    CH 275
    CYA 60
    I'm going to leave it there for awhile ,but I would like to get the CYA down a little more in time.
    Thanks to the people at TFTestkits that helped me out with the leakage problem I had when I got my package in the mail.
    I will only get my new regents from them from now on and Ill be telling my neighbors and friends about them too.
    BTW the sale ends tonight at 12:00 so if you need to order more stuff you better get on it.
    Thanks to all you guys on here that helped me out and answered all my stupid questions when I first got on the forum.
    6100 gal. In ground pool,1HP Pentair Superflo pump, 100 sq. ft. Cartridge filter , 3" tab dispenser, Aqua-Cal heat pump system ,Baracuda MX8 cleaner, in a Birdcage,Taylor K-2006 complete FAS-DPD chlorine kit.
    "Remember Folks Freedom Isn't FREE !!!"
    Re: I'm finally getting my CYA down a little at a time
    Casey's Avatar
    SW PA
    10,461
    I would let your CYA alone and if you want it lower yet, let the Spring rain dilute it down. You are right about where you need to be in the FL Sun IMPO.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Way to go Sgt!
    You'll be there and have a great summer this time around!
    Essential Links:
