Results 1 to 8 of 8
Thread: Is this considered cloudy ?
    Feb 2015
    Santa Clara,CA
    46
    Long story short.
    My CYA level was at like 200.
    CH was at 750.
    This was before I fired the pool guy and started TFP method.
    I replaced about 40% of water after which the pool looked very clear.
    Today I saw that it was not as clear as it was just after replacing water.
    My current CYA level is 90-100
    CH - 625
    It may be a false observation since I am new to this. I have attached a pic. Its 7pm PST so its not that bright outside.
    -Prasad
    30,000 gal,20'x40' IG (3-8.5 with diving board) ,Plaster,Pentair S8D110, Type of filer - DE,TF-100 test kit
    Poolsafe Automatic pool cover
    Re: Is this considered cloudy ?
    I wouldn't call that cloudy, though it could easily be less than perfect. The drain(?) grate is very clearly visible, as is the pool cleaner.
    Feb 2015
    Santa Clara,CA
    46
    Thank you. It's definitely not as clear as it was when I replaced 40% water and I am just maintaining a high level of chlorine since I do not want to replace any more water due to drought and high water bill.
    Getting the water clarity perfect when nothing major is wrong is primarily a function of getting all of your levels balanced just right and giving it a little time. If you post a complete set of water test results we might have a specific suggestion.
    Orlando, FL
    690
    Your question makes me laugh because when I ask that question, the answer is always but I never want to believe it. It usually takes me a day to accept that my readings are absolutely correct
    Sharkline Reprieve 15x52 (3/14). Still using Intex 2650 Sand Filter with Hayward Power-Flo Matrix 3/4 HP pump (6/15). Solar Cover cut into strips for easy removal, (2) 2*10 Space Saver solar panels. Swim Jet HD Robot (by Aquabot) (3/15). Chlorine Liquidator (4 gal). 4 person hot tub. Hard pipe is the way to go for improved flow! Retired Lil Shark (3/15). Starite Max E Therm 333k BTU Propane Heater w/ 24 gal tank (7/15).
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,051
    You'd only call that cloudy if you're a pool snob. But pool snobs only consider water to be clear when they can toss a quarter in the deep end and call heads or tails from the deck.
    Feb 2015
    Santa Clara,CA
    46
    Thanks everyone. You assured my confidence.
    My current levels.
    FC - 8
    CYA - Around 100
    CH - 625
    PH - 7.5
    TA - 16
    The water looks clear and hasn't become any more cloudy than it was before.
    I know I need to replace water for the high CYA and CH levels. I already replaced 40% and will probably not replace anymore due to severe drought and will maintain a high level of chlorine (liquid chlorine, no pucks).
    Thanks everyone.
    mrcarcrazy's Avatar
    Jan 2014
    Odessa, TX
    977
    Once my water temp is high enough for me to fetch the quarter I'm going to do that. I'll have my wife look though, as I'm blind.
    IG gunite/plaster pool/spa Started 1/17/14, Plastered 5/16/14
    Size: 12'-21'x39' free form, depth ranging from 4' to 7, attached 6 person spa with spillover.
    Equipment: Whisperflo 2hp pump, Pentair 30" sand filter, Pentair Mastertemp 400k BTU heater, 1hp Whisperflo for waterfalls, and a blower for spa floor
