Results 1 to 12 of 12
Thread: should I open my pool this early?
    Apr 2010
    Central NJ
    227
    I'm considering opening my pool on Saturday as it is turning green but with two nights in the twenties, I'm worried of the water freezing. Should I open it and treat the water before it gets worse or let it be for another week? if I open it, do I let the pump run overnight when the temp is below freezing?
    23K gallon, IG, Vinyl, Hayward DE-3600 Filter, Raypak 406A Heater, Hayward 1.5HP SP2610X15 pump aka AO Smith UST1152, TF-100 Test Kit
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,005
    Re: should I open my pool this early?
    where are you located?
    what is the temperature now?
    You are way better off opening a little early, preferably before the water gets above 50.
    If you dont anticipate an extended freeze, in the low 20s for days, then you will be fine.
    And yes, run your pump if the temp is below 32.
    Divin Dave,
    Apr 2010
    Central NJ
    227
    Yes my location would help, I'm in Central NJ. I usually open about three weeks later, but I couldn't cover the pool this winter and the pool is turning green earlier than usual. hence my question.
    thanks
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,005
    ahhh... ok.
    If I were you, I would go ahead and get it up and going and go ahead and SLAM it now, before the water gets much warmer which will make the algae grow faster.
    Just run the pump and you will be fine if it gets below freezing.
    I never close my pool and contrary to popular belief, it does get cold in Texas on occasion. Last year, high/low as 20s/teens for 2 weeks straight.
    Almost as cold this year and none of us TFPers here in Texas had any problem. (we mihgt have been a wee bit nervous though!)
    Divin Dave,
    The odds of a hard freeze are getting fairly slim in NJ, opening is probably alright, though it is tricky to be sure.
    Casey's Avatar
    SW PA
    10,453
    You sure you want to open with a snow storm on it's way?
    Jul 2012
    Central Texas
    436
    By 10am tomorrow temps should be above freezing. Lows expected at about 27 degrees. With pump running, should be fine. What's the current water temp?
    Central TX / 12K GAL / IG / SWG / DE filter / Pentair SVRS & 3 swim jet pumps / Spa bench and jets / Single body of water / No heater.
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Quote Originally Posted by jrguzmanr View Post
    Or wait a day or two until this storm passes.
    Please enter the location into your profile. That way it pops up when you post.
    Solar Blanket, Well Water, Borax Added. 68
    May 2013
    Long Island NY
    419
    I always open early by hooking up the pump and running it to balance the water. But I leave the cover on for another month or so. It helps protect the chlorine from the sun.
    19,000 gal - Vinyl IG - Sand filter -1.5hp. - Taylor k 2006 - Loop Loc cover
    Smykowski's Avatar
    Sep 2011
    3,065
    Quote Originally Posted by samt View Post
    This is exactly what I do, too.
    Mod Squad JVTrain's Avatar
    Feb 2014
    Central Minnesota
    5,080
    My pool still has ice on it, I think. Time to peak under the winter cover! I wait until the water temp hits 50, then the cover comes off and I get things started. Usually that gives me time, in case there is something that needs fixing during opening before the water starts having trouble.
    Isolated Spa - 345 Gallons
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Quote Originally Posted by Divin Dave
    You got that right on all counts, Dave!
    jrguzmanr: If it is convenient for you to open the pool this weekend, I would do it. If an early spring snow comes along, I wouldn't sweat it. Just make sure the pump is running if temps get below 32F just to be extra safe. We had 5+" of snow a couple of weeks ago here in DFW (yes, really!). It posed no problem for the pool - just made sure the pump was on while temps were below freezing.
