Results 1 to 7 of 7
Thread: sspool
    Mar 2015
    florence az.
    1
    sspool
    I'm new to salt pools. I was told the salt cell won't work if the salt level is to high. It's at 4100ppm now. It's a Hayward turbo cell -15.
    Re: sspool
    That is correct. Most brands, including Hayward, will shutdown the SWG when the salt level is too high. I believe the upper limit for Hayward is 4000 ppm. So it won't take very much water replacement to get the salt level down to something reasonable.
    Casey's Avatar
    SW PA
    10,423
    Re: sspool
    Welcome.
    Lower salt through dilution.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Re: sspool
    I guess that might be one advantage of Pentair, IC40 for me. It will produce cholrine even when there is too much salt in the pool. It gives a warning at 4500ppm but still produces chlorine.
    Green LED (Flashing): Salt level is above 4500 ppm. Chlorine is being
    produced but the salt level is too high which increases the risk of
    corrosion and deterioration of pool equipment and surfaces in and around
    the pool. Pool water needs to be drained and refilled one (1) foot at a
    time until the salt level is below 4500 ppm.
    Hayward Pool's Avatar
    Oct 2014
    Elizabeth
    426
    Re: sspool
    Salt is only lowered by splash out, dilution, and backwash. Hayward keeps the salt level as low as possible. The higher the level the most likely you can taste the salt in the water. Always have a pool store test salt level before adding salt or lowering level.
    Hayward Pool Tech
    80+ Years of Technologically Advanced Pool Product Manufacturing
    poolside@haywardnet.com
    Jul 2014
    Hope Mills, NC
    567
    Re: sspool
    Quote Originally Posted by Hayward Pool View Post
    Nope, we all test ourselves...never trust a pool store test.
    16 x 32 17500 gallons
    Vinyl in-ground
    Hayward 250# Sand Filter
    1 HP Pump
    Hayward SWG
    DFW, TX
    24,450
    Re: sspool
    Quote Originally Posted by Griswald View Post
    right! we can't even spell pool store around here.
