Results 1 to 18 of 18
Thread: SWG goes on and off ?
    Mar 2015
    Flagler Beach,Fl.
    7
    My SWG keeps going on and off ? Sometimes it stays on for days then starts going on and off ? My salt level stays at 3100 ?
    Also does anyone know the sequence, names, of chemicals shown on screen, I get just numbers ?
    Thank you,
    Tony
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: SWG goes on and off ?
    Welcome to TFP!
    You are going to have to help us by telling us what SWCG you are talking about.
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Welcome to the forum Tony
    It's kind of like asking how much change you have in your pocket. The make and model number will be very helpful.
    Please add your pools info and equipment into your signature as outlined here: http://www.troublefreepool.com/conte...etting-started
    Solar Blanket, Well Water, Borax Added. 68
    Mar 2015
    Flagler Beach,Fl.
    7
    Quote Originally Posted by Tony P97 View Post
    Thank you,
    Tony
    I have an 11,000 gal. in ground pool with an Aqua rite salt chlorinator with a T-3-turbo cell ? There is no other info on unit ?
    robdac's Avatar
    Jun 2014
    Weston, FL
    232
    The power LED goes on or off? The GENERATING LED goes on or off? All the LED's and the display?
    My unit is unpowered and completely blank (no LED's no display) when the pool pump is not running because it's also wired to the pool timer. This is normal.
    11K gal IG screened-in plaster pool w/ spa
    pentair 150 cartridge filter, Pentair Intelliflow VS pump,
    Aquarite AQR15 SWG, AquaCal Heatwave Heat Pump, TF-100 test kit
    robdac's Avatar
    Jun 2014
    Weston, FL
    232
    Thank you,
    Tony
    1. Salt level (ex. 3100)
    2. Water temp (ex. 88 )
    3. Cell voltage (ex. 27.6)
    4. Cell amperage (ex. 5.41)
    5. Percent output selected (ex. 18p)
    6. Instant salinity/salt level (ex. 3200)
    7. AL-0. Not used. This is the name of the device when attached to automation
    8. r1.59. Software version
    9. t-3. T-Cell type
    Here's a link to the manual:
    https://www.hayward-pool.com/pdf/man...AquaRiteXL.pdf
    Mar 2015
    Flagler Beach,Fl.
    7
    I have an 11,000 gal. in ground pool w an Aqua Rite salt chlorinator with a T-3-turbo cell ? There is no other info on unit ?
    robdac's Avatar
    Jun 2014
    Weston, FL
    232
    Thanks. We also need you to be more specific regarding it going "on and off" in order to help you.
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Here is a link to the manual in case you want to print it out or save it for the sequence of the display : https://www.hayward-pool.com/pdf/man...-AQR-Owner.pdf
    You might also ask Hayward the question to see if it's something they routinely run across. https://www.hayward-pool.com/shop/en...ontact-us-main
    Mar 2015
    Flagler Beach,Fl.
    7
    The wall unit power goes on and then the gen light will come on for about a few minutes , I can hear a click inside the unit and all the lights go off ? I will come back later and it might be on or off ? Like its resetting itself ?
    robdac's Avatar
    Jun 2014
    Weston, FL
    232
    1. Is it doing this?
    https://www.youtube.com/watch?v=TOJ6WcW9CYs
    2. How does the current limiter shown in the video look on your unit?
    3. How old is the cell? T-3 is pretty small for your 11K gal pool.
    Mar 2015
    Flagler Beach,Fl.
    7
    1. Yes
    2. Same
    3. 2-3 yrs old ? Took it off and clean inside, no build up . Hay say's the T-3 is good up to 15,000 gals !
    robdac's Avatar
    Jun 2014
    Weston, FL
    232
    IF your current limiter looks like it's bad (like the one in the video where it was physically coming apart) then that might be your problem. The end of the video even shows you where to order a replacement. If you can use a soldering iron it shouldn't be hard. It's an inexpensive fix IF that's your problem.
    The T-3 is probably undersized for your pool but it doesn't seem like a failed cell is the problem from your description. For contrast, my pool is also 11K gal and I have the T-15 cell. Probably overkill, but I caught a good sale. The smaller the cell and the harder you work it the faster it will wear out.
    In the mean time consider manually adding chlorine to maintain proper levels until you get the Aqua Rite repaired. Otherwise, you could have a green pool in no time.
    Mar 2015
    Flagler Beach,Fl.
    7
    Thanks a lot, appreciate your help ! I just ordered the part and will see what happens !
    My part was positioned differently but same part .
    Tony
    robdac's Avatar
    Jun 2014
    Weston, FL
    232
    Tony
    When I replaced mine it was obvious that the part was damaged just by looking at it. How does yours physically look? Good luck.
    Mar 2015
    Flagler Beach,Fl.
    7
    I replaced the current limiter and everything seems to be working Fine !
    Thank you All for the info ! It saved me a bunch of money !
    Tony
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Good Deal!
    Tony
    Divin Dave,
    robdac's Avatar
    Jun 2014
    Weston, FL
    232
    Glad it worked and was an easy inexpensive fix!
