Thread: Recommended Clarifier?
    What clarifier / conditioner do people recommend (if any)?
    Thanks!
    - jeff
    15,000 gal SWG pool, cartridge filter, all pentair equipment, variable speed pump, 400K BTU heater and spa, pebbletec finished
    Mar 2007
    Knippa, Texas
    289
    Re: Recommended Clarifier?
    I'm not sure what you mean by "conditioner" b/c many different products are called by that term. Some are useful or even essential, and some are a waste of money. CYA is sometimes called a "conditioner," tho, and it is a necessity for outdoor pools!
    Clarifier is generally not recommended on this forum. Most folks, I believe, consider it an unnecessary expense. I think it's Waterbear who says, "A clarifier can clear up your water in seven days; filtration may take a week."
    The BBB method and this forum are all about keeping one's pool sparkling using simple methods and inexpensive products. Many of the expensive specialty chemicals are unnecessary or needed only in special cases.
    ~Jules~
    My pool: INDOOR 13x27 rectangular fiberglass, built ~2001, BBB, TA-60 sand filter, Hayward two speed pump (1 hp/0.33 hp), 3/4 hp booster pump for solar heater
    Taylor K-2006 test
    Guest
    Clarifiers don't solve problems, they cover them up. If your water is cloudy you either have a sanitation issue or a water balance issue. Fix the problem!
    Let me give you an analogy. You have a dog that 'messes' on the rug. You can spray it with a deoderizer so it doesn't smell (use the clarifier) or clean up the mess (balance the water). If you do the first the mess might not smell but it's still sitting on the rug!
    searayboater's Avatar
    Jul 2008
    The Great State of Texas
    65
    Clarifiers = smoke + mirrors
    18' AG Pool, 6900 gallons, 55 sq. ft. Hayward Easy Clear Cartridge Filter, 1hp Power Flow LX Pump, North Texas
