Results 1 to 9 of 9
Thread: Sub-contractor recommendations (gunite and finished surface) in Houston Area?
    platipus's Avatar
    Feb 2015
    Houston, TX
    374
    My question is specific to the Houston area only.
    I pre-cleared this thread with JasonLion. It is OK to reply with the name of sub-contractors you can/would recommend. Positive responses only please. If you have one you would not use or recommend, please PM me instead of posting their info publicly.
    Specifically, I am looking for highly rated gunite installers and also Pebble Tec / Wet Edge installers. I know it's probably a short list anyway for the area, but I want to try and make sure that I am subbed out to a quality installer especially for those two areas.
    Thanks!!
    plat.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Sub-contractor recommendations (gunite and finished surface) in Houston Area?
    Pool Works Texas for WetEdge.
    Essential Links:
    Nov 2014
    Missouri City, TX
    71
    We just had our pool done and here are the subs that were used...both did a great job.
    Titan for gunite and Pool Works for WetEdge here in Houston.
    See pics under our build thread. SW Houston
    Pauline
    Oct 2014
    Kingwood, TX
    100
    Pool Works Texas did mine in Kingwood
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    There you go plat. Ask, and you shall receive.
    Essential Links:
    platipus's Avatar
    Feb 2015
    Houston, TX
    374
    That is awesome, thank you all!!
    plat.
    Jun 2013
    Huffman Tx
    190
    Modern Method Gunite , they also have a pebble tech division
    TW Pool's Avatar
    Mar 2015
    The Woodlands, Texas
    79
    Plat,
    Are you looking to GC your own project? I'm in The Woodlands and looking to do my own in the coming weeks... Although, I have yet to finalize the design phase. I've done a bit of research, and from what I hear Modern Method is one of the best. The only issue with them is that I am quite certain they don't work with anyone but larger pool builders with respect to gunite (I believe they do on PebbleX). I hear MMG shoots about 2500 pools with gunite per year and about 3500 with PebbleX. Another good one is South Bay, who I believe is owned by MMG owner's brother. Prestige Gunite and Houston Gunite also seem to be good and I know there are others that I am likely missing.
    platipus's Avatar
    Feb 2015
    Houston, TX
    374
    @TW Pool
    Not looking to GC. Just looking to ensure my builder uses a qualified sub for this vey important part of the construction.
    plat.
    Modern Geometric-ish Social Pool (4'-5'-4') ~13' x 47'. Sun shelf. Perimeter overflow spa. RiverFlow Swimjet. Dog ramp. "Bubble Lounge"
    Link to my patio build, completed 2013
    Link to my pool build, Aug '15 - Sep '16
