Thread: My wood deck is slippery - what can I do?
    Jul 2012
    Chicago, IL
    358
    I re-stained the deck around my AGP last year, it looks great now, but I found it can get very slippery if one has wet feet, which of course, happens all the time. I googled and seems most products out there are designed more for concrete or composite. Also, I don't want anything too abrasive because this is a surface that will come into direct contact with bare skin.
    I did find this which at least suggests it is comfortable to bare feet in the product description:
    http://www.amazon.com/Anvil-Additive.../dp/B00EIJMDXG
    Suggestions or personal experience?
    Dedicated TFPer since 2012 with recommended test kit
    AGP, 30 foot, 21,000 gallons with these homemade islands
    Hayward 150 sq foot cartridge filter, 1HP Waterway pump
    Raypak 400K BTU NG Heater! (Installed 2015)
    Installed in 2006? (just a guess, pool came with house I purchased in June 2012)
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,014
    Re: My wood deck is slippery - what can I do?
    Hi Pauls,
    putting a non slip additive into the sealer is about all you can do, short of completely re-coating the deck with a designed non skid coating, which you would then need to seal over again anyhow.
    Quote Originally Posted by Pauls234 View Post
    Divin Dave,
    Apr 2014
    California
    97
    Behrs deck restoration comes with a grip but you need to pick from solid colors otherwise you can stick with the stain you have now where you can still see the wood grain, just don't run and maybe use a rubber door may near the ladder.
    jcowart's Avatar
    Jun 2012
    Labelle, TX
    320
    The product you listed will work. Most paint suppliers will have a similar product. The problem is using it with stain. It will work but it's designed to be bonded by the medium used. Stain just does not build like a paint. Keeping the wood grain look with stain, the wear may not even last a season. If you do use it, it can be mixed with the medium or lightly broadcasted and another coat of medium added to bond it. The other products like Behr and Rustoleium deck restore will hide the wood grain. I have had mixed results with both products from clients. It does not bond well with fresh treated lumber. The coverage is not quite half of what is printed on the container. It can be mixed in different colors. They all get VERY hot in the sun. I did one in sandstone and a few in the darker colors. The darker ones would hurt "burn" your feet in the summer.
    17500 gallon Doughboy AGP, Hayward DE filter, waiting for the 1.5hp DB pump to go out.
    Learn to take the advice here and be trouble free or use the pool store's advice. "You can't do both and get very far"
    Jun 2013
    west fargo
    72
    Menards sells a sand paper like tape think it's called grip tape. I had to add it to our deck.
    20'x54" intex ultra Sand filter. with SWG Still work in progress will have Resin 24" fence around the top. Hooked to a 10x6 Deck that is attached to another 10'x6' Kids Club house. Slide from main deck into pool. Intex softwall lights. Kenwood Marine radio sealed in a deck box all Bluetooth controlled with Pyle 5" outdoor speakers.
    Jul 2012
    Chicago, IL
    358
    Thank you all for the thoughts and insights, this gives me some ideas to experiment with.
