Results 1 to 8 of 8
Thread: HELP! I spilled about 1 Cup of Behr concrete stain in my pool. Cloudy/milky
    Mar 2015
    Crescent City
    4
    Unhappy HELP! I spilled about 1 Cup of Behr concrete stain in my pool. Cloudy/milky
    I spilled about 1 cup of Behr concrete solid color stain (Siliconized 100% Acrylic) Water based stain in my in ground pool. It is about 20,000 gallons. It immediately caused a milky white plum that spiraled upward. I have been running my pump for 3 days and cleaning the cartridge once a day. I shocked it right away and it seemed a bit better but it is still cloudy. Does anyone have any suggestions on how to clear up my pool? Getting worried it will never clear up and I will have to drain 20,000 gallons of water and start over. Thanks in advance
    Re: HELP! I spilled about 1 Cup of Behr concrete stain in my pool. Cloudy/milky
    Welcome to TFP!
    You want to run with the FC level a bit higher than normal for a week or two. Also, try adding an enzyme treatment, for example Pool Perfect. That will help break down the chemicals in the stain that chlorine is not as good at breaking down.
    Mar 2015
    Crescent City
    4
    I am new to this so I am not sure what FC level is. I will go online and look for Pool Perfect. It seems the silicone is not breaking down. Is that was is causing the milky look to the pool?
    Mod Squad pooldv's Avatar
    DFW, TX
    24,450
    Mar 2015
    Crescent City
    4
    Unhappy Re: HELP! I spilled about 1 Cup of Behr concrete stain in my pool. Cloudy/milky
    I found Pool Perfect plus Phos. Free. Is that the enzyme you were talking about? To increse the FC level....is that just shocking it with the chlorine? Sorry, I am new to all of this
    Much better if you can find it without the PhosFree. PhosFree is not needed, raises the price, and can cause cloudiness of it's own.
    I wouldn't call what I am proposing "shocking", though the general idea is the same. Add some extra chlorine so there is more chlorine around to help break down the stain. But you don't need to add as much as you would when fighting algae.
    Mar 2015
    Crescent City
    4
    Thank you for your help. I am getting some today
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Welcome to the forum Shellielcj
    Seems you're on track to clear up the concrete stain. Just curious who takes care of your pool as far as testing and treating the water ??
    Solar Blanket, Well Water, Borax Added. 68
