Thread: Where do I put the lights? Pool goes away from house.
    Jan 2015
    Austin, TX
    1,095
    Ok so here is my design. (It will be pushed out about 2 feet because this plan was done too close to the house by mistake). Where would you put the pool lights? It probably isn't that big of a deal because the house is way higher than the pool so you would be looking down about 12' to it on the deck. I don't think it will be visible when sitting/standing in the house.
    Any thoughts that will still do the best to light up both the deep end and the shallow end?Screen Shot 2015-03-17 at 9.06.36 PM.jpg
    Pool is done! Only took 17 months! - Natural shape in-ground pool: 37x23, 505sq ft, 96ft perimeter, 7ft deep end, 18,950 gallons, tanning ledge, blue surf pebble sheen/luminous blue blend, Belgard coping, 910 sqft paver deck/walkways, retaining walls out the yinyang. Jandy SWG, 2 LED Color lights, VS 2HP Pump, 460sqft cartridge filter, PDA RS P8 controller. My build
    BoDarville's Avatar
    Jun 2012
    DFW, Texas
    3,841
    Re: Where do I put the lights? Pool goes away from house.
    My pool is laid out similar to your design. I have a single pool light located on the far side of the pool (furthest from patio) which is where the deep end is located. It provides ample light for the entire pool.
