Results 1 to 7 of 7
Thread: Softener water / SWG
    Aug 2014
    Texas
    30
    Hi
    I’m thinking to buy “SWG” for my pool this summer.
    The only concern I have is that I use the water that comes from the softener system in the house to fill my pool when it needs it.
    To maintain the softener filter you need to add some salt “pebbles “to the softener tank. That give you the effect of smooth and soft skin when you shower; plus it cleans the water.
    Does anyone see any “benefit” in adding “SWG” if you use the water from the softener system in the pool?
    By the way all the water in the pool at this point is treated with the filter system.
    14 x 36 In-Ground Fiberglass Pool Free form 14000Gal
    Hayward Super Pump series ( SP2610X15)
    Hayward Pro Series Top Mount High-Rate Sand Filter(S244T)
    Rainbow Lifegard Chlorine/Bromine Feeder ( not in used )
    Mod Squad tim5055's Avatar
    May 2014
    Franklin, NC
    9,184
    Re: Softener water / SWG
    Quote Originally Posted by Rafy View Post
    Hi
    They are two different things. The SWG is really a SWCG - meaning a salt water chlorine generator. Through a chemical reaction it turns the low level salt in the water to chlorine for sanitation in your pool.
    How much Pool School have you read? Start with this one:
    How to Chlorinate Your Pool
    Unless you are using Baqua or some other system you would be using one of the methods discussed to get chlorine in your pool.
    More detail on the SWG/SWCG can be found HERE.
    Support the site
    30,411
    The salt in your softener is there to produce a chemical exchange to remove (mostly calcium) from your water (it does not clean the water)
    The salt needed for an SWG is completely unrelated to that process and is mandatory if you decide to purchase an SWG.
    If you fill from a water softener, chances are that the pool salt level will already be high enough for the SWG to work, and you won't have to add salt (though this can vary).
    38,262
    Doing so can help keep your CH from rising as fast and thus lower the likelihood of getting calcium scaling in the SWG as well.
    There is certainly no problem doing both ... as long as you understand the differences.
    elwood58's Avatar
    May 2012
    Sun City West Arizona (2nd Home)
    653
    In water softeners, the salt is actually not what is softening the water. Part of the softener is a bunch of specially shaped polymer beads. The beads catch the hard minerals in your tap water. Every so often the beads need to be backwashed (cleaned). The salt brine that develops in the tank is used to backwash the beads so they can continue to remove hard minerals. This is often referred to as regeneration. Some salt does find its way into the soft water supply, but not a lot, and nowhere near the 3000-3500 ppm required by an SWG.
    19204 Gallon L Shape with a 10X10 2nd Step Baja Ledge. Intellichlor IC-40, IntellipH, Cartridge Filter, Pentair Heater/Chiller (Heat Pump). Tons of Deck with Deck Jets. Construction Complete 6/5/17.
    "If you don't measure it, you can't manage it!"
    Aug 2014
    Texas
    30
    Thank you all of you for your information and advice.
    I will try to get the "SWG or SWCG" (I know was the same only I was lazy) if I find a good price. However I have other problem with the pool at this point that have a priority. I will post later what it is. The best place to get information and guidance for your pool is here. I been learning a lot and my wife and I still learning.
    Thank you everyone!!!
