Thread: Pool Brushes - ss or combo for plaster?
    Sep 2014
    Fort Lauderdale, FL
    146
    I have plaster pool, Diamond Brite or similar. The previous owner of the house left me a combo brush where the nylon bristles are disintegrating and left floating in the pool. I'm about to buy a replacement, but wonder if I should get one that's just stainless steel bristles, or the combo style of stainless steel and nylon.
    What are the pros/cons of each? Combo brushes seem to be a few dollars more. Is there some reason why they'd be preferred over stainless steel?
    15k in-ground plaster, Hayward C900 cartridge, 1.5hp Pentair SuperFlo VS pump, Hayward AQR15 SWG, Barracuda G2 suction cleaner, TF-100
    38,524
    Re: Pool Brushes - ss or combo for plaster?
    If the plaster is new (< year) you should use a nylon only brush. After that, no real issue using the mixed, which is what I now have. The full SS is just going to be a little more harsh.
    I do recommend the whale-wall attachment. It only comes with a nylon brush, but I moved the tail over to a mixed brush.
    Sep 2014
    Fort Lauderdale, FL
    146
    Thanks Jason, I'll look for another combo brush. Makes sense to limit the harshness on the plaster surface.
