Results 1 to 7 of 7
Thread: Leisure Bay heating problem
    Adamsaudio's Avatar
    Jun 2013
    Atl
    36
    I've had this Leisure bay g2 tub for almost 10 years. The tub won't heat the water. I replaced the old element with a new one. The heat light on the top side control is lit, and both pumps are running properly,but the water isn't heating. I'm not measuring any voltage with my multimeter on the leads to the heater,but the supply to the board is measuring 240. The leads to the heater are showing 15.7 ohms of resistance. Does this mean the board is bad and needs to be replaced? If so, is it best to replace the board or go with a new control system like the one here?
    http://www.spapartsn...stems-a/310.htm
    My concern with the new control system is having the plumbing match up, as the current heater tube sits on top of the control Box, but the replacement has it going through the bottom. I have some experience doing pvc plumbing with my pool, but I haven't ever messed with any of the hot tub plumbing. Any guidance or assistance is greatly appreciated.
    24 ft Round Above Ground - 13500 gallons... Former Pool Frog user. Sand filter . Located just South of Atlanta
    Re: Leisure Bay heating problem
    There is a relay somewhere that turns the heater on and off, presumably somewhere on the main control board. It seems likely that the relay is failing to close and thus not sending power to the heater. Those relays can usually be replaced without replacing the entire control board.
    Adamsaudio's Avatar
    Jun 2013
    Atl
    36
    Is it similar to a relay that's found in a car? As far as it's unplug the old, and plug in the replacement?
    Normally yes. I am not familiar enough with Leisure Bay to be sure they do it that way, but nearly all tub companies socket the relays.
    Adamsaudio's Avatar
    Jun 2013
    Atl
    36
    Ok, thanks for the info. I'll research and see what I can find.
    Adamsaudio's Avatar
    Jun 2013
    Atl
    36
    This is the board that's in the tub. Would the black boxes with the yellow tube shapes inside be the relays?
    Yes, the mostly yellow parts are the relays
