Thread: Is a autocover manual controlled only?
    Jul 2014
    New England - MA
    310
    Can the operation of an autocover be controlled through Pentair's intellitouch or easytouch system? PB indicates it operation is strictly manual with a key. It makes sense you wouldn't want to remotely cover someone up. I'm just curious now...
    2015 Pool Build --> HERE IG 19'x47' w/ 7'x7' in pool spa; 3'6"-8' deep.
    Pentair 520 Filter, IntelliFlow VS XF Pump, IntelliChlor IC60 SWG, IntelliBrite/GloBrite LEDs, IntelliTouch w/Screenlogic2. 400K BTU heater. A&A G4V in-floor cleaning system. WetEdge Prism Matrix Pebble finish. TechoBloc Pavers and Coping.
    Test kits - Taylor K-2006 FAS/DPD, K-1766 Salt, SpeedStir
    38,246
    Re: Is a autocover manual controlled only?
    For safety reasons, they are typically only manually controlled.
    gtemkin's Avatar
    Jun 2008
    Seattle, WA
    738
    Quote Originally Posted by spool View Post
    ... PB indicates it operation is strictly manual with a key...
    That may be a local requirement but nationally, I don't believe you're limited to a key switch. The switch supplied with my auto cover was not a key switch.
    Having a remote control shouldn't be an issue either, but as you already stated, automatic closure would not be smart.
    If my memory is correct, I think the only requirement is that switch placement should allow full view of the pool when closing.
    21K gal 16' x 40' in-ground pool built 1959, old school with Jacuzzi bronze pump, American Products 24" Sand Filter & Americana Multiport valve, Jandy Lite2 millivolt heater, Coverstar cover, and classic Kreepy Krauly.
    Keys are not required, but the location of the open/close control does need to have a clear view of the pool. Operating the cover when you can't see the pool is very dangerous.
