Thread: First Water Test
    Mar 2015
    South Florida
    43
    First Water Test
    I just got the TF-100 test kit today and did my first water test. This is a pool less than a month old.
    PH - 8.2 (I will add 16 oz of Muriatic acid tonight)
    FC - 2 (Is this ok or too low?, I am still playing with the pump run time)
    CC - 0.5 (How do I bring this to zero?)
    TC - 2.5
    CH - 225
    TA - 80
    CYA - 20 (Not sure if the PB added any stabilizer) What stabilizer should I add?
    12K gallons, IG, Durazzo, Pentair cartridge filter, Jandy ePump JEP2.0 VSP , Pool started March 2, 2015, South FL
    Re: First Water Test
    The priority is to get the PH down. If your plaster was applied less than a month ago it will likely take a lot more acid than that. With fresh plaster you usually need to lower the PH daily to keep it under control. Try to keep the PH at or below 8.0 at all times.
    Trichlor tablets are good to use for the first month, as they raise FC and CYA levels very slowly, which is good for fresh plaster. If you do need to add stabilizer/CYA, look for granular cyanuric acid (any pool store will have it as well as most big box hardware store pool departments.
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    18,967
    Question: are you sure there's no CYA in that Jandy Nature2 Fusion Soft? And will it leave minerals in the water to build up and stain the plaster?
    Mar 2015
    South Florida
    43
    I have been monitoring the PH and adding acid almost daily. Richard320, I am not sure of anything, I am very new to pool stuff and thanks to this forum I am learning. I will read the manual of the Nature2 and find out anything about CYA.
    38,242
    I think the Fusion soft is the SWG version (not the trichlor version) plus the dreaded mineral pack that should be removed.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Quote Originally Posted by gonzo View Post
    No worries Gonzo, just take a bite at a time and all this will become easy before you know it.
    Ask questions as you need to, we'll be here to help.
    Essential Links:
