Results 1 to 11 of 11
Thread: Pump and Plumbing Diagnostics
    Feb 2015
    Baton Rouge, LA
    18
    My pump suddenly stopping pumping over night. The pump will not prime. Since then I have rebuilt the pump with a go kit which did not help.
    Problem:
    1. Occasional air bubbles coming out of returns. Overnight this because no flow out of returns.
    2. If I put my hand in the skimmer all the way down to the bottom I cannot feel a suction.
    Things I have tired:
    1. Rebuilt pump with go kit- did not help
    2. Drain king from the skimmer side- just a trickle of water coming out at the pump
    3. Plumbed the pump suction into a large bucket full of water and opened the pump discharge so that I could see the flow.- Lots of water flowing from the pump
    4. Connected the suction plumbing back up and watched the flow from the pump.- Barely anything coming out of the discharge
    5. Connected a 6.5hp shop vac to the suction line and blow through back into the skimmer.- It takes a minute or so but I end up with lots of bubbles. It looks like a hot tub in the skimmer. No debris coming out though. I did this once before rebuilding the pump with the same result.
    6. I have run water over the pump filter and connections with the pump running to check for air leaks. -No change in pump performance.
    Please help. Not sure what else to check here. I appreciate it
    13,500 gallon IG fiberglass, 3/4hp pump, sand filter
    Re: Pump and Plumbing Diagnostics
    There are two likely possibilities, either there is a fairly complete blockage of the plumbing on the pressure side of the pump, or there is a suction side air leak. I am inclined to suspect a pressure side blockage.
    What does the filter pressure gauge read?
    Have you checked all of the valves to make sure that the returns aren't turned off and the main valve is set to either filter or circulate? Try switching from filter to circulate and see anything changes.
    Feb 2015
    Baton Rouge, LA
    18
    Some things to add here.
    I recently bought a new multiport valve because the old body had cracks all over it. I found that one lateral was cracked and there was barely enough sand in my filter to cover the laterals.
    The multiport valve is the only valve that is in my plumbing.
    There is no change with different valve settings. I have even disconnected the pump discharge between the pump and the filter and there is almost no flow out of the pipe.
    Since changing the multiport valve and replacing the pressure gauge it has always read 0.
    That strongly suggests the issue is an air leak on the suction side of the plumbing.
    mas985's Avatar
    Pleasanton, CA
    11,737
    These two thing would indicate a suction side blockage to me.
    Mark
    Feb 2015
    Baton Rouge, LA
    18
    I have replaced the plumbing shown in the attached picture. Nothing changed with the flow from the pump.
    Where else could I check for an air leak? I have replaced the filter lid o-ring and made sure it was lubed. Also as stated earlier I ran water over the lid with the pump running with no change.
    What could I do besides a shop vac blowing back to the skimmer to unblock the line?
    I appreciate all the help so far.
    Have you tried using a drain king from the pump side and pushing back towards the skimmer? You sometimes need to remove the pump strainer basket to get good access to the input pipe.
    Feb 2015
    Baton Rouge, LA
    18
    I have not tried that. I will work on getting that done in the next day or two. How long should I leave the drain king in?
    If nothing happens in a couple of minutes, it is very unlikely that longer will help.
    Feb 2015
    Baton Rouge, LA
    18
    Update:
    I put the drain king on the pump side blowing back to the pool. A couple of quick bubbles and then nothing. I could not feel any flow. I followed something from another thread on here and plugged the skimmer for 10-15 seconds and got a few leaves out of the line. I kept repeating this and got a couple of leaves everytime. Eventually I was able to fill about half of a grocery bag with leaves from the suction line. The line is now completely clear of debris from the skimmer through the 90. I put the shop vac back on the line and was getting tons of flow through the line. Connected everything back up and tried the pump; still no flow. I assume there are more leaves on the other side of the 90. I am going to repeat my efforts again this evening as long as the rain holds off. Thanks for the help.
    Feb 2015
    Baton Rouge, LA
    18
    Final update:
    I used a plumbing snake and the drain king and after a few tries was able to free up whatever was causing the problem. The pump is running better than it has since we have moved into this house. Thank you all for the help.
