Results 1 to 9 of 9
Thread: coping choices
    Apr 2014
    Houston, TX
    19
    coping choices
    Hi all,
    I am in the choices phase of building my pool, and the builder provides 3 choices for pool coping. Limestone, travertine and flagstone, all same cost. The pool is going to be free form, with a raised rear wall and spa. I have no intentions of going salt route, and the pool will be in full sun most of the day. The concrete will be covered in cool deck.
    Is there a clear choice to the right material, I am not 100% set on a look yet, so color is not a big factor yet.
    Which is cooler to the touch, less maintenance, more stain resistant, more durable, are the type of things that are more important to me. Thank you for your help.
    Rich
    Re: coping choices
    what decking are you going with? you can achieve a "seamless" look by matching the decking and coping.
    Apr 2014
    Houston, TX
    19
    Re: coping choices
    Decking will be cook deck.
    38,547
    Re: coping choices
    Flagstone gets hot. Travertine is cooler. No idea about Limestone.
    I would go with Travertine as I think it holds up better to SWG ... if you ever change your mind.
    Or just do a full cantilever deck with no coping so it all matches. Very common in AZ to have it all Kool Deck.
    JayBauman's Avatar
    Sep 2014
    Katy, TX
    617
    Re: coping choices
    Your decision should come down to the type of equipment you're putting in (salt or no-salt) and/or how much work you want to put in (stone sealer or no sealer).
    You need to finalize one factor first, then make the decisions based on your first factor. For example, choose salt system. Then you'll want to go with limestone. OR....choose flagstone and avoid salt like the plague, unless you want to seal it every few years. I think once you put a line in the sand, the good folks around here can help you with your decisions.
    23' x 37' IG 18.5k gallon SWG w/ raised spa, Build Thread -->Here
    Wet Edge® Pearl Matrix®, Hayward® SwimClear™ 525 ft², Hayward® Goldline Controls® PS-8
    4x Hayward® TriStar™ pumps, Paramount PCC2000® ICS, TF-100 w/Speedstir
    Mar 2015
    Forney, TX
    15
    Re: coping choices
    We evaluated cost / return and travertine is pretty expensive, unless you're already doing a very expensive deck and pool, in which case it's relative.
    we evaluated flagstone vs. brick vs. manufactured bullnose stone (concrete product.). In the end we chose to concrete product due to it's uniformity, and because we know we can always replace cracked or chipped / stained pieces with like pieces since they're factory molded and mass produced.
    Flagstone is rustic and natural but we wanted a balance between all the moss-rock features like fountain and spa spillway..
    Hope this helps you out. the concrete products look nice, and are smooth to the cheeks and the feet.
    Kpag's Avatar
    Feb 2015
    Dallas TX
    159
    Re: coping choices
    I think you should, from a design standpoint, look at your house too. The coping and deck should tie in with the fixed elements of your home (brick, stone, formal, rustic, etc...).
    IG ~12000 gallon 1988 freeform pool with IG spa, Hayward equip, Ecostar pump. Remodel done: NPT Arctic 1x2 tile in Lagoon w/ gray thinset & Light Pewter grout, French Gray PebbleSheen w/ grey fittings, Leuders buff eased edge limestone coping w/ Light Buff mortar, buff mastic
    Oct 2014
    Austin/TX
    27
    Re: coping choices
    If you go with a natural stone product, I recommend sealing it, regardless of using a SWCG or not.
    Concrete products are generally more durable than natural stone, but may not give you the same look or match the surrounding design. If you don't have a need to match stone in the design, go with concrete. You can still seal concrete - especially if you want to protect it against stains. Concrete sealers are much less expensive compared to natural stone sealers.
    If I didn't already have flagstone, I would've opted for a bullnose cement product.
    Limestone and sandstone are both easy to work with, but are highly vulnerable to damage from freeze/thaw cycles, salt, etc. when used around pools. If using limestone around a pool, opt for Lueders (and seal it), which tends to be more dense than most other limestones.
    Sep 2011
    NorCal
    19
    Re: coping choices
    I inthe process of getting bids to redo our pool. For the coping, we are going to a tumbled rock from a 12" safety brick coping. It used to be a 13.5" before the last remodel and now have a ridiculous mastic gap. We're going with the tumbled so it can butt up to the Cool Deck walkway around the pool. Any recommendations for tumbled rock or a different product that won't break the bank?
    approx. 18k gal, IG gunite w/ fiberglass overlay, Polaris 280, Centurion 1hp/1.65 sf pump, AO Smith 3/4 hp/ 1.50 sf booster pump, Mytilus FMY-150 cartridge filter. Pool remodel has started and will be upgrading to Pebble Sheen Ocean Blue, Pentair FNS Plus 48 DE Filter, LED multicolor or white light, and Pentair Intelliflo VS pump. Pool automation and solar heat automation to come later.
