Thread: Concrete Paver and Travertine seal
    Feb 2015
    DeLand
    4
    Just finished my pool with pavers. I sealed my driveway and it looks great ( wet look) but it is more slick when it gets wet so I am a little nervous around the pool area.
    I am currently debating Polymeric Sand and looking for the best one to use for pool areas. I used the Home Depot stuff on my front porch and it gets moldy and needs cleaning.
    Are there any products that folks here have had great luck with?
    I'm in Central Florida if it matters.
    Mike
    Re: Concrete Paver and Travertine seal
    Bump
    txnole's Avatar
    Aug 2014
    Amelia Island, FL
    544
    I had understood (perhaps incorrectly) that polymeric was fairly universal item - same stuff just different labels. We have used one from Quickcrete on our driveway pavers and it got in all the nooks and crannies just fine.
    Regarding the cleaning, take a look at this WET AND FORGET http://smile.amazon.com/Wet-Forget-1.../ref=pd_ybh_17 Good stuff and hasn't disclored our Tremron pavers.
    Regarding the sealant, we just used the DuPont Stonetech last week on travertine. It is not noticeably slicker. We have a screen enclosure and slightly different humidity than you (Amelia Island), so YMMV.
    COMPLETED BUILD THREAD - 15'x29' rectangular offset shotcrete pool; 14,100 gal; 5'x7' raised spa with 400k btu fire feature; 7' spillover; 25' leuder stone raised bond wall w/waterfall; Pentair SWG; Pentair VS (pool); Pentair 3/4hp feature pump; 1hp spa blower; Pentair Cartridge filter; Pentair “Easy Touch 8” wireless; Dolphin Oasis Z5 robot; Solar Hydronics iSwim solar panels; Mansard Screen Enclosure; walnut travertine deck; 1 very happy kiddo.
    Mod Squad pooldv's Avatar
    DFW, TX
    24,485
    I've seen a couple of threads here where people have used polymeric sand and been happy with it cutting down on sand getting in the pool. Maybe try a search on polymeric (upper right corner), that is an uncommon enough term that you should get pretty good search results.
