Results 1 to 8 of 8
Thread: Herbicides in pool?
    Mar 2015
    Winfield, KS
    45
    Herbicides in pool?
    We live in a rural area and have a wheat field right behind the house. Mid January we had several shrubs loose their leaves and some appear to have died (it's a little early to be sure). We suspect the wheat field was sprayed but have not been able to verify that. We did talk to a farmer who said the most likely thing that would have been sprayed that time of year was 2,4-D.
    The cover was off the pool by that time since all the trees had lost their leaves so there is a possibility that whatever it was got into the pool water.
    My research so far indicates that there should not be a health risk to swimming in that water but I wanted to see if anyone had more knowledge of this.
    Thanks!
    Greg
    Round 18' Sharkline pool, 8600 gallons of well water. Hayward 40gpm single speed pump and DE filter
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Herbicides in pool?
    I can't imagine anybody spraying 2,4-D in January. It is absorbed through the leaves, so would be ineffective at that time of year, and can actually reduce yield. 2,4-D is not usually used on wheat in the fall or winter at all. Late March here in Indiana would be the earliest spraying time, both because it needs green foliage and because it doesn't work well below 50F.
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    I'd call an agricultural extension office from your state. Here are a few suggestions for your county (Cowley): https://www.google.com/#q=cowley+cou...tension+office
    Solar Blanket, Well Water, Borax Added. 68
    Chlorine will break it down. There might be a short term risk (or not, I don't know) but after a few days it will be gone.
    Mar 2015
    Winfield, KS
    45
    Quote Originally Posted by kiss4afrog View Post
    They are right across the hall from me , but she was out today so I thought I would get some input from here until she can call me back.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Maybe something else, but not 2 4 D this time of year even in Texas.
    Essential Links:
    Mar 2015
    Winfield, KS
    45
    Just an update; the lady from the extension office just called and she is pretty confident that my plants suffered winter kill. She said the last 2 to 3 years have been really hard on landscape plants, and that the freezing/thawing cycles we had this year probably did them in.
    So a little later in the spring I will be able to enjoy the pool....... after planting new shrubs
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Good to hear! (well better to hear than herbicide)
    Essential Links:
