Thread: Have a simple question
    Dec 2014
    Rivas, Nicaragua
    83
    Have a brand new ALL MOSAIC TILE pool. the water has been in for three days. I ave all the parameters in the correct range but for the TA being a bit high. I presume it will be normal for this go trend a bit high as well as the ph tends to drift up each of the three days because of the special quikset between the tiles for a while?
    Just lower the ph and "aerate"? Meaning fluff/churn up the water?
    Warren in Rivas, Nicaragua
    10,000 Gallon all mosaic tile pool- Whisperflo 2 speed 1.5hp - Pentair CC plus 420sf - Polaris 280 - 2 Intellibrite LED - 2 Intellibrite LED bubbler - 4 Jandy deck jet - 1 sheer descent - no automation - autofill - K-2006 test kit - pool deck 540sf - porch attached to pool deck -740 sf - My build thread
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    Re: Have a simple question
    Aerate means anything that mixes the water with the air. Your bubbler, sheer descent and deck jet will all help. pH may rise quickly with that stuff running.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Hi MrNica,
    Just reinforcing what JohnT said. your water features should aerate the water nicely. Keep an eye on your PH, and adding the acid will also lower the TA.
    The quickset Im sure is probably contrubuting, that that part of it should settle down probably within a month I would think.
    Divin Dave,
