Thread: Cutting quartzite
    Palm Springs area, CA
    70
    Cutting quartzite
    I have an elevated spa with a waterfall into the pool. The waterfall is made of stacked and mortared quartzite ( I believe this is the material, but I'm not a geologist).
    One of the tiles at the top was missing when we moved in. There are some leftover shards of quartzite that I am going to try to hew into the right shape, and then re mortar in place.
    All of the existing tiles look rough-hewn, ie the edges look fairly rough, definitely not cut with a tile saw.
    Is there a tried and true method for cracking quartzite? It is roughly 1/2 to 3/4 inch thick. Hammer and chisel?
    11,000 gallon in-ground pool/spa combo, pebble-tec, Sta-rite system 3 cartridge 300 sqft, Pentair Whisperflo WFDS-6 2 speed 1.5 HP full-rated, formerly Starite Max-e-Glas 2 HP up-rated single speed, Sta-Rite Max-E Therm natural gas heater. Jandy Aqualink RS Onetouch. Manual vacuum. Chlorine.
    Melt In The Sun's Avatar
    Oct 2009
    3,899
    Re: Cutting quartzite
    Do you have a bunch of extra pieces...I mean, enough to mess up a couple and be OK? I would try cutting it to be close in shape using a tile saw or a grinder, then chipping the edges with a hammer and stone chisel.
