Thread: Windows control panel
    meatloaf's Avatar
    Feb 2008
    Gilbert AZ
    373
    I want to create a desktop icon for control panel.
    How do I do it?
    Thanks
    My pool is a 10,500 gallon (420 Sq Ft ) kidney shape. STA-RITE HRPB30, Sand filter 30" 98 GPM, 1 HP Maxi-Glas 2 pump, BBB Method, Taylor K-2005 test kit, 50 Watt 12V low-voltage pond light illuminates the pool at night for a nice soft glow.
    Re: Windows control panel
    If you drag (with the right mouse button) the control panel icon to your desktop, it will give you the option to create shortcut here.
    Hope this helps.
    20' Easy Set frame pool 8800 gal. Sand filter. Stenner metering pump. BBB for 7 years now, no turning back.
    meatloaf's Avatar
    Feb 2008
    Gilbert AZ
    373
    It didn't work. Is there another way?
    meatloaf's Avatar
    Feb 2008
    Gilbert AZ
    373
    I got it. Thanks
    Nick's Avatar
    Jun 2008
    Bristol, UK
    36
    Another method (assuming you are using Windows) is to right click on the desktop, select NEW and then SHORTCUT. Navigate to C:\Windows\System32\Control.exe and then select it.
    That will give you a direct link to Control Panel.
    Intex 16'x48" AGP 5,000 (uk) gallons
    Intex 635 pump
    Bio Diesel filter bags
    4 solar radiators and a solar cover
