Thread: Pump Making Odd Sounds - What Can I Do?
    Mar 2015
    Florida
    4
    Hello!
    I cleaned my filter yesterday afternoon but didn't notice that there was a small water leak because of the rubber ring not being securely in place. It was leaking for about an hour or so. The pump turned on this morning but is making an odd whirring sound. I fixed the filter so it's no longer leaking, but when I heard this sound I turned the system off to get feedback before running it. Please let me know if you have any feedback on what I can do to fix it, thanks!
    http://youtu.be/OL9F4AWlUYE
    Edit:
    A picture of the model information is attached:
    Is it safe for me to continue running it even while it's making this sound?
    30,432
    Re: Pump Making Odd Sounds - What Can I Do?
    Does water flow into the pool? Does your pump "prime"?
    Mar 2015
    Florida
    4
    Hi Dave,
    I'm not sure what priming means, would you be able to explain further? Yes, the water is flowing into the pool and appears to be operating normally. I posted a video and picture before, not sure why it's not showing up. Here it is again just in case:
    https://www.youtube.com/watch?v=OL9F4AWlUYE
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,025
    One thing to check, is remove the fan cover on the back of the motor, and see if something got in there and the fan is ticking it.
    Other than that, I dont know what the noise might be.
    Divin Dave,
