Thread: Switching to SWG
    Sep 2014
    Atoka, TN
    15
    Switching to SWG
    After two summers of using the Permasalt system, I'm ready to switch over to using a SWG. While the water with Permasalt was easy to maintain (replace the chamber every year, add salt), there just wasn't enough FC in the water for my liking.....especially with our son getting ready to start using it this year. I've read a ton on the site and know more or less what I want buy, but I'm curious if I need any other equipment other than what I have. Any thoughts are appreciated.
    Also, how often should I replace the sand in my SwimPro filter? Might still be the original sand (6+ years old) for all I know. I see there are also a few different filter sand alternatives as well.
    Thanks in advance.
    19K gal 27' round AG; SwimPro by Hayward High Rate Sand filter, model SW256T; Hayward Power-Flo Pump, 2 HP, model EP1550LX; Circupool Si +30 SWG; K-2006 FAS-DPD test kit from Taylor
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,011
    Re: Switching to SWG
    Hi there,
    you dont need any more equipment. It looks like what you have is fine, and I think you'll be happy with a SWG system.
    You really dont have to replace the sand in a sand filter if you dont want to. Its a myth that sand wears out. Of course the pool stores like you to think that happens to they can sell you a lot more of it. Sand is already millions of years old when it is put in the filter, so if it was gonna wear out, it would already be wore out.
    Cant remember the last time I was as the beach and saw any wore out sand! hahaha! (I didnt make that up, I read it somewhere!).
    enough funnyness though. If you simply deep clean the sand, it will be good as new. I think a deep cleaning every 3 or 4 years might be applicable. Really though, each situation and pool will vary.
    Here is how to deep clean your sand, and there is even a video.
    http://www.troublefreepool.com/threa...-a-Sand-Filter
    Of course, if you prefer to replace the sand, then that's fine too. But its a real pain to get all that sand outta there! A shop vac is the best tool for getting the sand out.
    Hope this helps!
    Quote Originally Posted by CelticsFanForever View Post
    Thanks in advance.
    Divin Dave,
    Sep 2014
    Atoka, TN
    15
    Thanks for the info Dave. Totally makes sense about the sand......duh right?
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,011
    haha!
    Right!
    Divin Dave,
    Mar 2015
    New Orleans, LA
    81
    Don't do much with sand filters but I have seen sand clump up and get like cement. Then you need to change it. You can tell by getting your hand in there and feeling it. I have worked a lot with Jandy Salt systems. The new FSOFT1400 cell system is the way to go other than the older PLC1400. The cells are easier to clean and less expensive to replace.
    Smykowski's Avatar
    Sep 2011
    3,065
    Quote Originally Posted by ConradM View Post
    It sounds like that's a situation where CH got out of control, and scaling happened in the filter. That would be one of the few situations where a sand change would be required.
    In general, our recommendation is that sand very rarely needs to be replaced. In most instances, deep cleaning will suffice.
