Results 1 to 7 of 7
Thread: Garden hose filter for adding water to pool?
    Oct 2010
    michigan
    284
    Does anyone know of a good garden house water filter that actually reduces TDS(total disolved solids?).
    This may be a mute point, in the process of testing the snow and rain for TDS, If they have a high TDS no point in a filter.
    15,000 gallon inground fiberglass pool with spa. 350lb Sand filter, 1.5 hp pump, and heater
    30,403
    Re: Garden hose filter for adding water to pool?
    No filter will mechanically reduce TDS.
    After 200+ posts, I am surprised that you want to even test.......they are irrelevant to what we teach.
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    If you were located out west there are companies that do reverse osmosis on pools as it's cost effective compared to the cost of water out there and restrictions on pools. MI ... don't think anyone does it.
    http://poolservicestech.com/tag/reverse-osmosis/
    There are hose end filters but their effiency is hotly debated as some are compared to putting a clean white sock on the end of your hose doing the same thing
    I use a PreFresh filter for my Spa: http://www.amazon.com/Pre-Fresh-Gard.../dp/B00AXP8B9O
    Hot Springs sells a nice filter but I'm not sure it's seventy dollars nice.
    http://www.shopthepoolandspacenter.c...FdCmaQodqBQA_g
    What is your TDS level, who and how did they measure it and why are you concerned about it ??
    Solar Blanket, Well Water, Borax Added. 68
    Oct 2010
    michigan
    284
    I,m picky, i have very slight iron staining, can only really see it if its cloudy or sun setting.
    I use a sponge mop with little slots cut out and put vitamin c drops in, Last about 2 months.
    Also use a culator packet.
    Has been improving and lessoning each season.
    minxcal's Avatar
    Jul 2013
    South FL
    80
    Hi Smooth2222!
    I had the same issue with my last pool (well, fill water) and came up with this - which was very effective.
    Good luck!
    http://www.bohowillow.com/2013/09/a-...water.html?m=1
    Many kinds of filters can filter out iron particulates, but hardly any will filter out dissolved iron, and the ones that do aren't really very good at it. If you have an iron particulate problem, it is certainly worth using a filter. But if your problem is mostly dissolved iron there is little you can do that is cost effective.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Snow, and rain will have extremely little to no TDS because it is condensed water. Once rain water hits the ground or anything else, it picks things up that will add to the conductivity of the water...which is how TDS is measured. TDS in and of itself is irrelevant to pool chemistry. The number alone doesn't tell you what you need to know, only that there are some dissolved solids in there. It could be all salt or any combination of other dissolved minerals. No hose end filter is going to reduce these minerals.
    As a rule, RO treatment is difficult to locate, and very expensive. Usually quite a great deal more so than fill water.
    That bohowillow link showing a filter for Iron removal will not remove dissolved iron that can cause iron staining. Removing all the Iron from water that will cause pool staining has do be done through some kind of reaction, even if it is just Ion exchange such as in a softener.
    Essential Links:
