Results 1 to 12 of 12
Thread: Elephant pad under new pool install?
    Feb 2015
    Bardstown KY
    139
    We are having a new 33' installed in a few weeks and are looking at underlayments. The pool store didn't recommend anything and they typically just use sand. After researching on our own, we think we should do more and planned to purchase a gorilla pad. I've run across the generic 'elephant pad' and wondered if anyone had any experience with these? Are they truly comparable? Would love to save some money where we can, but don't want to regret it.
    27k gallon 33' round, partially buried 22" Sandman sand filter, 1.5hp 2 speed TidalWave pump, Pentair 'Lil Shark with leaf canister, TF-100 Test Kit
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Elephant pad under new pool install?
    The gorilla pad typically gets the best reviews.
    Essential Links:
    pwrstrk's Avatar
    Elverson Pa.
    4,758
    If your looking for a more cushy feel from the gorilla pad, it won't give it to ya. It's primary function is a barrier for your liner from nut grass, roots, rocks, and things like that.
    Jeff
    Casey's Avatar
    SW PA
    10,453
    I used one because my hill was made up of fill (rocks, bricks, cinder blocks n glass). I didn't want to chance it.
    Feb 2015
    Bardstown KY
    139
    I'm looking for it mainly for protection of the liner, but have also read that they may help reduce indentions which would of course be nice. We have a lot of big trees, and moles around...any extra layer will help.
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Welcome to the forum BellaBuggy
    Congratulations on the purchase. Hope to see install pictures to follow the progress
    Solar Blanket, Well Water, Borax Added. 68
    Mandolina's Avatar
    Apr 2014
    Los Angeles USA
    67
    We have two Gorilla pads over the original tarp. I purchased one that I thought would be too small, then I purchased another that turned out to be too big - so we ended up using both. Very soft footing! It has kept the gophers out. When filling your pool add a small amount of water to stretch it out (Also a good time to check for any leaks), then smooth out all the wrinkles and fill it up.
    16' x 48" 5000 gal. Intex Ultra Frame AG Pool, Los Angeles, CA
    Hayward Full-Flow Cartridge Filter System with 2 Speed Power-Flo Matrix Pump,
    Intex SWG, Intex Wall Mount Surface Skimmer, Solar cover & Solar Roller,
    Confer Plastics A-Frame 7200 Adjustable Roll-Guard Safety Ladder,
    Kokido SkoobaMax Vac, Custom Canine entry & exit ramps,
    Makdaddy's Avatar
    Jul 2012
    Springfield Illinois
    119
    Quote Originally Posted by Mandolina View Post
    I also went with the gorilla pad, We dont have gophers, but we do have cicadas . So if you know the cicadas cycle in your area, might want to consider it.
    We know a guy that had them come up, after his pool was up for 3 years,they were o the 10 year cycle. tons of holes in his liner
    --- Greg----
    24 x 54 Round Cozumel AGP with Grand Entrance Step 14500 Gal
    Running ntex Krystal Clear Saltwater System with E.C.O.
    A/G Cristal Flo II Sand Filter Tank w/ 2HP, 2-Speed Dynamo pump -Zeobest
    TFT Test Kit---Gorilla Floor and Foam Pool Cove--Half Deck
    yostmatt's Avatar
    Jun 2014
    Hollidaysburg, PA
    174
    I too have one. I bought it on eBay pretty cheap. My ground was good, but figured the extra protection was worth the few extra bucks.
    ~Matt~ Radiant Metric 24'x52" 14k- built into a slope. CircuPool Si-30 SWCG. Jandy 200 SqFt cartridge filter. Pentair Optiflow 2-speed 1HP pump. Wanda the Whale. TF-100 Test Kit. Hard Plumbed.
    My Build w/ lots of pics
    May 2014
    LA, USA
    16
    I installed the Gorilla Pad over foam board underlayment, worked very well.
    http://www.troublefreepool.com/threa...2-quot-AG-Pool
    AG-Intex Ultra Frame 32 ft x 16 ft x 52 in, Water Capacity (90%): 14,364 Gal, Hayward SP1091WM Dyna-Skim Above Ground Pool Skimmer Kit
    Intex 2650 GPH Sand Filter Pump & Salt Water System CS20110
    3/4" Extruded Polystyrene Foam Board Insulation, Gorilla Floor Padding
    Borated sparkle added
    Casey's Avatar
    SW PA
    10,453
    Quote Originally Posted by BellaBuggy View Post
    Don't count on it to reduce indentations unless you smooth and compact the sand base. I did not have enough time to pay attention to detail. It shows, even though I have the pad.
    Feb 2015
    Bardstown KY
    139
    great install! that looks like an awesome base.
