Thread: New pump and motor Hayward advice
    I have a 16x32 inground pool. Current pump/motor is Hayward SP2607X10 Super Pump 1-HP Max-Rated Single-Speed Pool Pump.
    This is the 1 HP model. I need to replace. I can get the 1.5 hp model for about 20 dollars more.
    Thoughts on 1 Hp vs 1.5 hp.
    I have a Hayward sand filter also.
    Thanks.
    22,000 IG vinyl liner
    sand filter
    LQ 8 gallon
    Jacuzzi Hot Tub
    420 gallons
    Re: New pump and motor Hayward advice
    Unless you are having some specific problem with your current pump, or are adding a water feature you haven't mentioned, it is better to stick with the 1 HP version. With pumps smaller is almost always better.
    You can save a great deal on electricity by switching to a dual speed version of the pump. It will cost a little more up front and save you roughly 50% of the electricity needed to run the pump.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    Mike it doesnt really matter if you replace it with exactly the same model or not, unless you just want to.
    Would recommend to stay with a 1 HP though.
    Also, we would recommend going with a 2 speed pump. The 2 speed will give plenty of circulation on the low speed and result in very significant savings
    on the electric usage.
    Divin Dave,
    guys, thanks for the expert advice !
    What two speed pump should I get?
    Does it take different wiring, I am on 220... now. I am worried if I change styles I will need to replumb my lines.
    thoughts- how does two speed work?
    sand filter
    LQ 8 gallon
    Jacuzzi Hot Tub
    420 gallons
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    5,003
    you might have to reconfigure some plumbing just because of physical difference in your current pump vs a new one. Plumbing is so easy though. If you can measure, cut and glue...you got it made. But then again, maybe not. Here is Hayward 1 HP 2 Speed pump. http://www.inyopools.com/Products/02201170001134.htm
    Note- no endorsement given for the this webisite. Its for reference only.
    On High Speed, the motor runs at 3450 RPM pumping a full flow rate of water
    On Low Speed, the RMP is cut in half to 1725, and you get half the flow... the sweet part is that at slow speed, you only use 1/4 of the electiricity as on high speed
    The two speed pumps are 220V just like you have now.
    If you are using ab automated system of some sort, you will need to run 1 more wire from the controller so you can select between high and low speed.
    If you dont have a auto controller and only use a timer (or not), then no extra wire is needed.
    You have to be careful when ordereing, and make sure you get a pump with the speed switch already installed on the pump. (they come with and without the switch installed).
    Quote Originally Posted by mikemedic View Post
    Divin Dave,
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    The two speed is an excellent idea as it can pay for itself over time.
    Solar Blanket, Well Water, Borax Added. 68
