Thread: Where to purchase plastic bins for a pool cover?
    Catanzaro's Avatar
    Jul 2014
    Monmouth County, New Jersey
    2,256
    Does anyone know where you can purchase plastic bins, which could hold sand or water, instead of water bags for a pool cover?. Last year I was at a friends house. The neighbor used plastic bins that looked like water bags, either filled with Sand or Water (not sure). They were long and straight just like the double water bags. I have looked on line, but could not find anything. I am not concerned about sand in the pool. If there is enough slack in the winter cover, there will not be any movement as snow, ice and water build up. Usually, I will pump the water off the cover unless completely frozen or snow.
    I do not want to take regular plastic containers and fill them up with water. While the concept is there, the plastic becomes brittle in the cold. These were long straight plastic containers for support.
    14,700 gallons IG Pool Vinyl Liner - Octal Circulation System
    Hayward Pro-Series 350 LB. Sand Filter Model # S270T - 2" Plumping
    Hayward CL2002 Chlorinator - Hayward Super Pump 2 HP Model # k48m2n111
    Hayward AQR9 SWG 25K Salt Cell & TF-100 Test Kit + Speed Stir
    Gulfstream HE125RA - 117K BTU Heat Pump - Date of Build is 11-2013
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Where to purchase plastic bins for a pool cover?
    One brand name for them is Aqua Blocks. That should help you find them. In the Swim carries them.
    Catanzaro's Avatar
    Jul 2014
    2,256
    John, Thank you.
    I found these on Amazon for a good price. There are some negative reviews that the lids do not stay on and some have blown in the pool. I am assuming you can fill these with water but not as much as the water bags. Even if you filled these half way and the water froze you still would have room for expansion.
    With regards to the tops, it is as simply attaching tie straps on each end so they stay on securely. Ironically yesterday was the windiest day in NJ and some of the water bags that lost water were in the pool. I am hoping that these will work. At this point I will order only 12 from Amazon to see what they are like.
    When they arrive I will fill with water and place on my concrete. Then start up the blower that has air speeds of over 200 mph and perform the test. You will see results in a few weeks. Thank you.
    Kiss4aFrog's Avatar
    May 2013
    Hudson, WI
    2,680
    Just a couple shopping options. Let us know how the ones you ordered work out for you.
    http://www.intheswim.com/p/unbreakable-aqua-blocks
    http://www.amazon.com/Aqua-Blocks-Co.../dp/B0037TSUHG
    Solar Blanket, Well Water, Borax Added. 68
    Catanzaro's Avatar
    Jul 2014
    2,256
    I ordered 12, instead of 6. A little shy of $60. This was less expensive and the same blocks. Thank you.
    http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
