Thread: Proper height and slope for reverse negative edge spa
    Jul 2014
    New England - MA
    310
    Finalizing design with PB for our spring time build. We're considering changing the spa spill over feature to a reverse negative edge similar to the image below. Our spa height is 18" higher than the pool. What is the an appropriate spa height and slope angle to maintain a nice even sheet of water flowing over the edge?
    2015 Pool Build --> HERE IG 19'x47' w/ 7'x7' in pool spa; 3'6"-8' deep.
    Pentair 520 Filter, IntelliFlow VS XF Pump, IntelliChlor IC60 SWG, IntelliBrite/GloBrite LEDs, IntelliTouch w/Screenlogic2. 400K BTU heater. A&A G4V in-floor cleaning system. WetEdge Prism Matrix Pebble finish. TechoBloc Pavers and Coping.
    Test kits - Taylor K-2006 FAS/DPD, K-1766 Salt, SpeedStir
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: Proper height and slope for reverse negative edge spa
    Sorry, that's a question for your designer that most of us will have a hard time answering correctly.
    Essential Links:
    It is more about construction precision than it is about height and slope. Mostly it needs to be installed exceedingly level and uniform to get that uniform sheet of water effect.
    Jul 2014
    New England - MA
    310
    Thanks guys, I figured as much. When the snow melts the PB will be taking us to a few nearby pools with the same design.
