Results 1 to 10 of 10
Thread: How long should shocking take?
    Jul 2012
    Bel Air, MD
    52
    Hello all,
    I have been shocking my hot tub for days, but I can't the bacteria down below the recommended level. How long should shocking the hot tub take? I am getting fed up and am on the verge of dumping the water and just filling it back up again.
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Re: How long should shocking take?
    I would just dump it if I thought it was Bacteria. How do you know that you have a Bio Population like that?
    Essential Links:
    Jul 2012
    Bel Air, MD
    52
    Quote Originally Posted by Patrick_B View Post
    Sorry meant Combined Chloramines (CC). I am using the TFTestKit and I am measuring 2 -3 X 0.5 ppm. The count hasn't dropped for days. It isn't BIO Population.
    Swampwoman's Avatar
    Apr 2012
    Grand Rapids, MI
    3,778
    I second the draining, then using Ahhhhsome to cleanse the system, then starting afresh. Once you're out-of-whack on a hot tub, draining makes more sense than shocking. Pools are different due to volume and comparatively lower water temp, plus being open as opposed to closed.
    In ground vinyl Grecian, 24k gal, Hayward 220t sand filter, VGreen VSP 165, Hayward SWG, Raypak NG 265k heater, dolphin m4.
    Helpful Links:
    GET A TEST KIT Chlorine/CYA Chart How to SLAM About Metals & Stains
    Patrick_B's Avatar
    Jun 2011
    Midland TX
    14,998
    Oh, OK, I was just curious about that.
    Essential Links:
    Richard320's Avatar
    Jan 2010
    San Dimas, CA (LA County)
    19,075
    Have you been using Monopersulfate shock at all? It reads falsely as CC. http://www.taylortechnologies.com/Ch...P?ContentID=33
    Jul 2012
    Bel Air, MD
    52
    Quote Originally Posted by Swampwoman View Post
    OK - just picked up some Ahh-Some. Reading the instructions tells me that I drop a table spoon into the filled hot tub, let it filter for 20-30 mins, then drain it, clean it and re-fill it. Your instructions suggest otherwise. Can someone help me rationalize the difference? Thanks.
    Does someone have instructions
    No I strictly use "Chlorinating Concentrate" which has Sodium dichloro to build up the CYA and then straight chlorine from a pool store to keep the chlorine levels up.
    38,547
    Swampwoman said to drain, then refill and use the Ahhh-some, then drain and refill again. Pretty much what the instructions say except for the preliminary drain to remove what you can first.
    It is a hot tub, I would drain anytime there is a problem. Not sure how to further rationalize $5 in water to drain
    Jul 2012
    Bel Air, MD
    52
    Yeah - this is exactly what I have been trying to avoid. I don't care about the money - it's the 300 gallons I want to avoid wasting.
    38,547
    Water your plants.
    Generally hot tubs need to be drained on a regular basis anyway.
